Results 1 to 14 of 14
Thread: What now?!! 1998 1100RT
    Mar 2016
    Los Angeles
    Me again.
    Well, after the clutch bearing replacement, the bike is running well. I went away for a week and just got back on the bike for a spin. The instrument panel is being weird. In neutral, the neutral light is very dim and the battery light is occasionally on. Also, before rollaway, only one ABS light is lit.
    Every time I pull in the front brake lever, the battery light comes on and the tach drops to zero. This happens at rest and while rolling at any speed. There is no loss of power or any change in performance in any way.
    How might I go about diagnosing this? What should be my first investigative move..
    Thanks!
    N
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    I would be looking for an open ground.
    Where is going to be the issue.
    Ufda happens..........
    Mar 2016
    Los Angeles
    Yeesh. Any hints as to where to start..? And how would I go about identifying an open ground?
    Ground is Brown wire.
    Disconnect the positive from the battery
    Connect an ohmmeter with the black wire to the negative of the battery.
    Then with the positive lead start measuring resistance of each brown run.
    You should read less than 0.5 ohm in each case
    It's a big task and will require fairing and tank removal.
    Mar 2016
    Los Angeles
    Oh boy.
    Thanks. How might something like this happen? Bike was fine, sat for a week and now this...
    Quote Originally Posted by mtlla70 View Post
    Oh boy.
    Corrosion, that may have been going on for some time. It's 20 years old now.
    Check the multi pin plug/socket assemblies as well for corrosion.
    Mar 2016
    Los Angeles
    Gotcha. Thanks!
    I should mention that there are splices inside the harness where a feeder ground splits off to several. That may be where the problem lies.
    Keeps things interesting.
    Mar 2016
    Los Angeles
    Yikes. That doesn’t sound good...
    Mar 2016
    Los Angeles
    I was just reading on an old thread on avrider about a “chassis ground for the instrument cluster”? Where would that be?
    Mar 2016
    Los Angeles
    It was just a fuse!
    Well, I cannot tell you how happy I am to report that it was just a fuse. I had no idea that a blown fuse would make the instrument cluster go all freaky; I had imagined it would just shut it down, so I hadn't checked it right away... anyway, I'm glad that there were a couple of spares in there, so all is good. Thanks again for the input here - I am learning a lot about my bike!
    Cheers!
    I took for granted that you had already done that!
    Good news, now go ride.
    Mar 2016
    Los Angeles
    Ha! That would be a fair assumption!
    I am so new to BMWs that every day is a learning opportunity!
    Thanks again!
    Oh boy.
    If is sat for a week without a battery charger connected ... there's your problem.
  1. 1998 1100RT valve cover gasket
    By mtlla70 in forum Oilheads
    Last Post: 03-17-2017, 05:22 AM
  2. Replies: 11
    Last Post: 12-13-2016, 01:40 AM
  3. 1998 1100RT oil change
    Last Post: 09-18-2016, 05:49 AM
  4. 1998 1100RT Valve Adjustment
    Last Post: 09-06-2016, 03:05 PM
  5. 1998 1100rt loose rear end
    By 41107 in forum Oilheads
    Last Post: 07-23-2004, 01:34 AM
