ncpbmw1953
Member
Howdy,
I have 30,695 now on my the '16 RT I bought new. With this RT, and the '13 F800GT before it, always tire pressure would display within just few seconds of rolling past at least 6mph. I've had 5 tire changes between both bikes, and this had zero impact on TPC readout. A few hundred miles ago the same dealer shop that has done all my tire changes installed a set of Conti RA3 GT on the RT. When I left the shop that day, TP didn't display after 4 miles or so, so I stopped and called the shop and they said this was typical, 'they all do this...' so give it some time to reestablish communication. OK, even though this never happened previously to me on either bike. A few miles later both F & R pressures displayed and worked all 20 miles of the way home that day. Ever since then it's been erratic, and getting worse. Today the F came on after 1/2 a mile, and the R never did display. In the past week or so I've only been out a couple other times, and once it started right up displaying as per usual, but the other few times the typical pattern appears to be the front displays after .3 to .7 miles, and the rear displays after 7 to 9 miles, or in today's case which was less than 7m in total the rear never came on. I tried deflating and re-inflating tires and did another test ride, and no joy.
That both front and rear seem to be affected makes me think the control unit that receives sensor inputs might be starting to fail; as well the batteries are hopefully are only a couple years old in the sensors as the bike was manufactured between Jan-Mar 2016 so it seems doubtful it's a sensor battery issue to me.
Again, the shop told me essentially 'they all do this', which is patently false in my experience. Has this ever happened on your wethead TPC system? For those familiar w/ changing tires on these, what might possibly have been done during the tire change that might have caused this?
Thanks in advance. I've got a 4K mile ride starting on Tuesday so I'm guessing I'm hosed for this trip as to getting a warranty repair as clearly is behaving abnormally and this is jeopardizing its value for me.
