Results 1 to 5 of 5
Thread: New brake pads now vibration
    Registered User Motodan's Avatar
    Dec 2007
    Indiana
    Only 8,800 miles on this '08 RT, but bought in January and still going through it. While it didn't need pads, I decided to replace anyway....wanted bike in a new state at beginning of ownership. Went with EBC "HH"...easy off with old, on with new. Small amount anti-seize on back plate. Rode this morning getting some slight to moderate shutter/vibes when slowing down. Looked at old pads and noticed while one end of pad material was not tapered the other was. I haven't looked at the new installed pads (just threw them on)...did I miss checking for tapered end (if there is one) to go on at front of disc rotation...or ????
    WHEN WILL A LEARN TO LEAVE WELL ENOUGH ALONE?!
    F750GS
    MOA #46783
    Most pads have no taper in the direction of travel (the narrow sides). I don't think that is your problem and doubt the EBC pads are tapered there. Most likely you got some contamination on the rotors or pads during installation or didn't break them in properly after installation.
    Here is a decent tutorial...
    https://www.revzilla.com/common-trea...ge-your-brakes
    Don't let a mistake doing something dissuade you from learning and moving on. No-one is born knowing this stuff. Over time you will advance to new and more interesting mistakes. I have found that the permanence of the education rises with the value of the parts ruined.
    Lee A. Dickinson - Danielsville, GA USA
    Airheads #3480 | Iron Butt Assn. #8914
    1992 R100RS - 1993 K1100RS - 2013 R1200GS
    Dec 2007
    Indiana
    Quote Originally Posted by beemerphile View Post
    Only 15 lightly used miles on them thus far, so not sure break in process is a concern at this stage. And I did clean rotors during pad install. I called EBC for their insight, they said to put 50 to 75 miles on them to see if they smooth out...if not I'm to call them back. Will see what transpires. Never had a problem with new pads before.
    F750GS
    MOA #46783
    Sep 2009
    Chestnut Hill, MA
    Motodan - I saw your post and even though I have a 2015 RT, I thought I'd reply. I changed all the pads on my 2015 RT yesterday at 29,320 miles, using EBC products. I followed the JVB video to the letter. I did not put anti-seize on the back of the six plates, but did put a very thin layer on the pins (two in front, one in back) that seem to hold everything in the calipers. I took the bike out for a 10-mile ride this afternoon, and all seemed fine. I noticed no immediate difference between the feel and response of the new pads versus the old.
    I've read various bits of information about what is called the "bedding" of the pads. It seems this is the process of getting new pads to adhere (if that's the term) closely to old rotors. EBC offers some information on this process (which lasts about 300 miles) here: https://ebcbrakes.com/articles/motorcycle-bed-in/
    I hope this is helpful.
    JG
    John Gamel - BMW MOA Consumer Liaison
    2015 Ebony Metallic R1200RT
    Watching the sunrise outdoors statistically increases your odds of having a good day. And needing a nap after lunch.
    Dec 2007
    Indiana
    Appreciate the replies. After putting an additional 200 miles on those EBC pads I still wasn't satisfied...they will not stop without vibs from moderate shuddering. I ended up buying (the made of gold - $$$$) BMW pads. As you know they're expensive, but in this case, it was certainly worth it. Brakes are like they should be now, no more shuddering. EBC told me to call them back on this, which I will do. This was an unusual experience with their product. Used them before without problem...I think at least one of the sets is defective.
    F750GS
    MOA #46783
  1. 1987 R80RT Brake vibration
    By jgp1854 in forum Airheads
    Last Post: 11-21-2015, 09:24 PM
  2. 2005 R1200RT Front Brake Vibration
    By RoudyBob in forum Hexheads/Camheads
    Last Post: 05-08-2013, 12:26 AM
  3. Front brake pads dragging afternew pads were installed
    By rideaway in forum Hexheads/Camheads
    Last Post: 04-24-2013, 02:41 PM
  4. Replies: 4
    Last Post: 10-14-2009, 10:39 PM
  5. OEM brake pads
    By SHOOTER55520 in forum Flying Brick K-bikes
    Last Post: 05-09-2009, 11:44 PM
