Results 1 to 5 of 5
Thread: '03 650 CS Turn Signal Issue
    All stock, no farkle / bling
    Switch on for right turn: both front / rear turn lights flash normal and normal flash from indicator at instrument cluster.
    Switch on for left turn : both front / rear on BOTH sides flash normal speed but no indicator flash at instrument cluster.
    Removed lamps from right signals, still no indicator at cluster and obviously no right signals flashing.
    I have not disconnected right side wire at switch yet or at connector behind triple tree but will try this tomorrow.
    Any thoughts????? Bad switch?
    Buzz ( Lightyear )
    03 650CS Turn Signal Issue
    Traced problem to left side diode for signal / hazard flashers
    Mansfield,MA
    Nice job.
    Mod Squad
    2009 F800GS 1994 TW200
    Diode value
    Anyone know the specs / ratings for these diodes? They are the gray plastic housed units. Current OEM list price is $45 & change
    Diode / Turn Signal
    Original diode is a “BYV27-200” rated at 200V -2A
    Found one rated just over @ local brick & mortar retail for under $2.00
    Many online for pennies.
    Now to go ride....
  1. The most bizarre turn signal issue - 91 R100GS
    By theblueeagle in forum Airheads
    Last Post: 09-04-2018, 03:50 AM
  2. K100RS Turn Signal Issue
    By joeangi in forum Flying Brick K-bikes
    Last Post: 05-12-2011, 03:14 AM
  3. K75 Turn Signal Issue
    By edswope in forum Flying Brick K-bikes
    Last Post: 05-02-2011, 12:05 AM
  4. R90/6 Turn Signal Issue
    By Dave_Hemenway in forum Airheads
    Last Post: 11-23-2010, 05:53 PM
  5. Turn signal issue
    By JALAIMO146577 in forum Flying Brick K-bikes
    Last Post: 08-10-2009, 01:20 PM
