Results 1 to 11 of 11
Thread: 1996 k1100rs brake lights
    Hello all. I'm having issues getting my brake lights to work. All wiring is hooked up properly and the bulbs are fine. I checked the fuse panel on the left side of the bike and none are blown and no fuses are missing. Any ideas? Also, is the brake fuse located somewhere other than the fuse box on the left side of the bike is inline somewhere? My klimer manual doesn't state.
    Key on? Kill switch in run position?
    Does tail light work?
    Does brake light work when pulling front brake lever?
    Does brake light work when pushing rear brake pedal?
    Is your bulb monitor showing a fault?
    Do the rear turn indicators work?
    Does your fuel guage work?
    When did the brake lights last work?
    What changed or what did you work on since they last worked?
    Oct 2015
    alexandria, va
    is engine running when you are checking them? kickstand up?
    just went through this....no brake lights. lots of troubleshooting only to find they were working as designed. kickstand up, engine on, lights work.
    Marshall
    92 K75s
    94 K75s
    09 K1300s
    Marshall,
    I might be wrong (I remember a time or twenty when I was), but looking at the K1100 schematic, I don't think the side stand needs to be up or the engine running for the brake lights to work. It would be nice if someone who currently owns a K1100 could confirm this one way or another for us.
    The brake and tail lights are fused through Fuse #1. Do you have voltage at Fuse#1?
    http://i16.servimg.com/u/f16/16/61/73/02/sikrin11.jpg
    Registered User AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    There's a separate taillight wiring subharness that uses a big blocky connector behind the taillight, kind of to the right. Check for voltage there and make sure that the contacts are clean. It's an unsealed design so you can check voltage on both sides before you disturb anything, if you're curious.
    Anton Largiader 72724
    Tech articles - YouTube
    Virginia Motorrad Werkstatt BMW motorcycle service and repair in central Virginia
    Oct 2015
    alexandria, va
    Marshall,
    fuse #1 does not get power unless the ignition is on and the kickstand is up. it only provides brake light power, not tail light power.
    I have a 96 K1100RS sitting in my shop now. checked it. a lot. (while troubleshooting the brake lights.)
    kickstand down = no engine power
    no engine power = no brake lights
    Marshall
    92 K75s
    94 K75s
    09 K1300s
    LOL, I was there with Marshall. Damn kickstand!
    '93 K75s
    '96 K1100RS
    Quote Originally Posted by mlytle View Post
    That's one sweet looking K11RS SE.
    Oct 2015
    alexandria, va
    Quote Originally Posted by JeffDiCarlo View Post
    that pic was taken right after we picked it up from seller...and before dualks spent 3 hours cleaning it!
    it is currently undergoing midlife refresh of, well, everything.
    Marshall
    92 K75s
    94 K75s
    09 K1300s
    Hopefully bwoods1100 (the OP) will get back to us and see if that solved his problem. He is new to this forum and hopefully he realizes that this works better when feedback comes full circle with a result.
    98lee thank you for clarifying the subdtle nuances of forum operation. Lots of great responses I see. Sorry about the delay , I haven't had the chance to play mechanic in a few days. Kickstand is up, engine power is on, both brake lights are new, every fuse in that bike is good (when you don't know which one it is you just check all of them haha), and lastly I have power to the brake light bulb harnesses (verified via test light). I'm guessing this means it a ground issue.
  1. 1996 k1100rs
    By PeoriaMac in forum Flying Brick K-bikes
    Last Post: 05-13-2011, 11:25 AM
  2. Front brake pads? - 1996 K1100RS
    By moondog59 in forum Flying Brick K-bikes
    Last Post: 03-15-2011, 02:07 PM
  3. 1996 K1100RS - Brake Pad thickness?
    Last Post: 08-18-2010, 10:23 PM
  4. 1996 K1100RS - Brake Bleeding
    Last Post: 08-10-2010, 03:11 AM
  5. Brake lights w/Signal Minder - 1996 K1100RS
    Last Post: 06-26-2010, 09:22 AM
