Results 1 to 6 of 6
Thread: Re-installing OEM skid plate front 2 bolts on '17 F800gs after oil change
    Jun 2007
    Williston, VT
    The 4 main nuts holding the skid plate are no problem, but how the heck can you get the nuts on the bolt on the two front bolts. For expediency, I'm gonna put the head of the bolt through the top on the inside, and screw the nuts on the outside. Not ideal if I bang it up on a trail, but I'm stumped.
    Can anybody help?
    It came back from Max's installed correctly after my first dealer oil change though, so they've found a way.
    Calgary
    Leave those two bolts alone next time and remove the long cross bolt that holds the front bracket to the engine.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2019 F850GSA
    Jun 2007
    Williston, VT
    Thanks Ed.
    I will take a look at it in the morning. I never even considered that. I knew someone would have an easy fix.
    Mansfield,MA
    Is this the one?
    From MAX BMW- https://shop.maxbmw.com/fiche/Diagra...0&rnd=07242017
    I'm due on my 2009, I can't remember having a problem.......Don't know if there has been a change.
    Mod Squad
    2009 F800GS 1994 TW200
    Jun 2007
    Williston, VT
    Easy peasy
    ...when you do it right.
    Thanks again Ed. I'm smarter now!
    Jun 2007
    Williston, VT
    That's the one.
    Thanks Omega Man too. Just saw your post now.
  1. Replies: 5
    Last Post: 08-21-2019, 06:53 PM
  2. Replies: 10
    Last Post: 05-16-2015, 03:13 PM
  3. Skid plate for a K75?
    By toddlamp in forum Flying Brick K-bikes
    Last Post: 01-01-2010, 09:48 PM
