Results 1 to 4 of 4
Thread: Flywheel holes / Oil / R60/6
    Jun 2007
    Minneapolis, MN
    Hi Guys,
    I'm in the process of replacing Main Seal and Oil Pump "O" ring and YES the crank is blocked!
    When I removed the flywheel bolts, oil seeped out of every hole - I read how Brook Reams used RTV to repair the leaks:
    https://www.google.com/url?sa=t&rct=...rRqlp4cVnXXYKi
    This is my second main seal replacement and I don't recall seeing oil seep from Flywheel bolts - bike only has @ 26k on odometer and I'm quite confident these are original miles.
    Also, picture should be rotated 90 degrees to the right
    Any suggestions always appreciated!
    Ken Tuvman
    Excelsior, MN
    K1200GT & R65LS
    Liaison 20774's Avatar
    Brook is the man on this! I had my /7 flywheel off years and years ago at an Airhead Tech Day but don't recall any issues at the time. I don't think it's a huge issue, just seal things up as he did and press on.
    Jul 2017
    I just sealed mine this winter same as Brook did, worked fine. I had 2 leaking.
    Dave Hutton '78 R100S (mfg 7/77)
    Jun 2007
    Minneapolis, MN
    Thanks Kurt - as always - you are a huge asset to this forum! Don't know how you keep up but you sure do!
    So, the main seal was the original White and hard as a rock - it had been obviously leaking - I'll run to the local auto parts store and pick up a tube of grey RTV he suggests.
    Thanks again!
    Ken Tuvman
    Excelsior, MN
    K1200GT & R65LS
  1. '77 R100S Oil leak, flywheel bolt holes
    By kinterridge in forum Airheads
    Last Post: 04-12-2018, 05:38 PM
  2. Motor Holes
    By 72598 in forum Airheads
    Last Post: 10-13-2008, 06:26 PM
  3. Watering Holes
    By JK in forum Campfire
    Last Post: 09-20-2008, 11:30 PM
  4. What Are These Holes For?
    By Geoff in forum Airheads
    Last Post: 07-16-2008, 03:56 PM
  5. Holes
    By thompsonr in forum Flying Brick K-bikes
    Last Post: 04-21-2008, 02:50 PM
