Results 1 to 6 of 6
Thread: Bolted up a used Ohlins rear on my R1100R today
    1998 R1100R SE ABS
    Sep 2016
    Kansas City, MO
    While doing this I really noticed alot of oil around the final drive. I must have a leak somewhere there.
    I had picked up used Ohlins front and rear shocks from Parts Haus a while back, and thought I would get them rebuilt. Unfortunately the rebuild hasn't been in the budget. I expect I'll require a different spring.
    The front one has an obvious leak while the rear looks good. The rear is the one I really need, so I went ahead and swapped out just the rear shock today.
    I have not adjusted the preload yet. Not exactly sure how to do that, or if it's absolutely necessary. I figure I'll put a twist or two on the adjuster and take it for a spin and see how it handles bumps ...
    Ed
    1998 R1100R 75th Anniversary Special Edition w/ ABS
    1998 R1100R SE ABS
    Sep 2016
    Kansas City, MO
    first test ride results -
    I did notice a difference in ride.
    The old Showa just seemed plush until I hit a bump, and then if it was a good one, it would bottom out.
    The Ohlins is fairly firm. Maybe I need to back off the preload?
    I haven't notice the Ohlins bottom out yet. I haven't ridden two up yet either.
    I did also set the seat up to the highest setting (was mid).
    One other thing I did notice: We have a cr@ppy curb for our cr@ppy driveway, and when I rode over that at the end of the test ride it did not hit bottom.
    More to come ...
    Ed
    You adjust the pre-load by setting the sag.
    https://www.motorcyclenews.com/new-r...uspension-sag/
    Lee A. Dickinson - Danielsville, GA USA
    MOA 80364 | RA 29650 | ABC 3480 | IBA 8914
    1976 R75/6 - 1992 R100RS - 1993 K1100RS - 2013 R1200GS
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Ohlins used to have their setup instructions on-line, but I couldn't find that pamphlet this morning. So, here ya go:
    Ohlins rear bm125.pdf
    Their springs tend to run a little on the stiff side when new, but age well.
    You'll notice a difference when you get around to swapping out the front, too.
    1998 R1100R SE ABS
    Sep 2016
    Kansas City, MO
    Quote Originally Posted by beemerphile View Post
    Thanks Lee, I'll check that out
    Ed
    1998 R1100R SE ABS
    Sep 2016
    Kansas City, MO
    Thanks Paul
    Actually the R1100R uses a BM634 front and BM635 rear and I have downloaded the PDFs for those. I'll dig into those and Lee's link when I have some time. I did reference the BMW install doc to determine where to mount the preload adjuster. Not the best spot (above the muffler), but it works.
    Ed
  1. Ohlins Rear Shock
    By sw3dl1 in forum Airheads
    Last Post: 03-10-2017, 02:28 AM
  2. R1200RT Rear Ohlins install
    By gr8ridn2 in forum Hexheads/Camheads
    Last Post: 08-11-2009, 01:29 AM
  3. Help: Rear Ohlins on 1200GS
    By klrobins in forum Gear
    Last Post: 04-12-2007, 11:43 AM
