Results 1 to 8 of 8
Thread: Throttle lock for r1200r, 07 with heated grips?
    Need your help!
    What is the best throttle lock that will not interfere with my heated grips?
    I have used the locks on other brands over the years and understand the danger. These are only used on long highway trips to give my right hand a break.
    Charlie
    Jun 2007
    Portsmouth, NH
    I have one of these on my 2011 R1200R. I greatly prefer the little toggle switch over locks that twist to engage.
    http://www.excelthrottlecontrol.com
    rabid reader dbrick's Avatar
    Santa Cruz CA
    I have a Kaoko on my '07 R with heated grips. Works fine, but while I thought I'd use it, I never do.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Put an o-ring between the grip and the bar end weight.
    Still learning groop1's Avatar
    Jul 2007
    OC, CA
    I also use the Kaoko on my 07 GS with heated grips. Works fine
    The Kaoko has one flaw common to that type - as the grip heats up - the locking force increases. I use mine as a "drag" on the throttle - I want it neutral so I can let go at any time and not have the bike instantly slow down, yet be able to easily roll off the throttle. I have carpal-tunnel and arthritis - and that's what lets me ride. Problem is - it tightens up as the grip heater warms up. One chap did make one that wouldn't do this - it had a spring loaded plate that pressed against the end of the throttle tube - the spring allowed for some expansion of the tube with heating, without increasing the friction force. Clever design, dunno if I can find who it was who made it though. I should have bought one..
    And the O ring under the bar-end works well too - and isn't effected by the grip heater.
    Douglas Williams
    Mar 2006
    Raleigh, NC
    This is what I use on my R1200R. I like the thumb pad on the back that allows me to move it without taking any part of my hand from the grip. I can also push down with my index finger without any problem. It's easy to overcome when throttling down and, like me, it's cheap.
    http://www.2wheelride.com/GoCruise_t...0control2.html
    Doug
    Sent from a Galaxy, far, far away
    Registered User YeehaStephen's Avatar
    Deep in the Heart of Texas
    I'm a Cramp Buster/Throttle Rocker kind of guy.
    And the Chinese knock offs aren't too bad either. Though they do weaken in time if you ride in hot weather. But you can buy a whole box of them cheap!
    https://www.ebay.com/bhp/throttle-rocker
    Yeeha! Stephen
    R1200RS, R1200RT, R1200R, (R1150RT = Donated To Charity)
    "Why eat a Burger when you can have Pie?!" Miss Vicki @ Lost Maples Cafe - Utopia Texas
  1. Heated grips makes throttle bind up....?
    By flhfxd in forum Oilheads
    Last Post: 11-13-2016, 03:08 AM
  2. Replies: 24
    Last Post: 11-30-2013, 04:15 PM
  3. Replies: 14
    Last Post: 01-30-2013, 07:07 PM
  4. Replies: 28
    Last Post: 02-25-2010, 01:27 AM
  5. Sticky throttle when heated grips on 'high'
    By jacco in forum Oilheads
    Last Post: 04-29-2005, 02:38 PM
