Results 1 to 5 of 5
Thread: R60/6 Main Seal Parts Replacement Question
    Registered User kentuvman's Avatar
    Jun 2007
    Minneapolis, MN
    Hi guys,
    While doing clutch spline lube noticed a bunch of oil in the case - so planning to replace the main seal & O ring - do I need to block the camshaft before removing the clutch and flywheel?
    The manual says to replace the Flywheel bolts (5) and from what I've read it's a good idea to do so.
    Manual also says to replace the clutch filter head screws (6) - is this optional or necessary?
    My driveshaft bolts have washers - the Max BMW fiche says I need to buy new bolts & washers - have read if I can easily screw in the existing bolts no need to replace them and I can leave out the lock washers and use Blue Loctite.
    For the Oil Pump "O" Ring they're showing (4) replacement metric bolts for the cover - p/n 07119904357 / I know Northwoods Airheads had replacement bolts that were Allen head but trying to place the order with one vendor. Should be the same.
    Thanks for your thoughts & input!
    Ken Tuvman
    Excelsior, MN
    K1200GT & R65LS
    Feb 2005
    Trinity, NC
    Yes, you have to block the crankshaft.
    No, you should not reuse the driveshaft bolts with washers, and no you can't reuse those longer bolts without the washers. Just buy the new shorter bolts. Don't be the cheapest thing on the bike.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Registered User ebeeby's Avatar
    McKinney, Texas
    The driveshaft bolts come in two lengths- those with lock washers and those without. Using bolts designed for lock washers and then not using the lock washers will be too long (at least that's how it is on the R75)
    And yes the crankshaft needs to be securely blocked from the front to prevent it from moving forward when the flywheel is removed (again, true at least on the R75). Movement of the crankshaft forward will slip a part off its pin and will require complete tear-down of the engine.
    Some bolts are engineered to stretch when installed and are "one-use". Others are not. If BMW says to replace the bolts it is likely because of this difference (Porsche experience)
    1973 R75/5
    Jun 2007
    Minneapolis, MN
    Thanks guys - advice taken
    Ken Tuvman
    Excelsior, MN
    K1200GT & R65LS
    Liaison 20774's Avatar
    Snowbum has some discussion about flywheel removal as well as torque values for /5 early /6 versus later /6 models...don't know which yours is:
    http://bmwmotorcycletech.info/flywhe...valwarning.htm
  1. 02 K1200RS Clutch Slips After Main Seal Replacement
    By chris04107 in forum Flying Brick K-bikes
    Last Post: 06-08-2015, 12:14 PM
  2. Replies: 26
    Last Post: 05-15-2015, 06:18 PM
  3. Rear Main Seal replacement mid-90s K75S
    By 88bmwjeff in forum Flying Brick K-bikes
    Last Post: 05-01-2013, 10:38 PM
  4. Rear Main Seal replacement Tips
    By jimv in forum Airheads
    Last Post: 03-14-2012, 09:18 PM
  5. Rear main seal replacement help '85 K100
    By chuck_donahue in forum Flying Brick K-bikes
    Last Post: 10-27-2010, 05:18 PM
