Results 1 to 12 of 12
Thread: 2012 RT engine symbol in dashboard multi function display
    Registered User ajaxthegreater's Avatar
    Jun 2013
    Highlands Ranch, CO
    My bike has some 76K plus miles now and I have been noticing recently that the little engine with an exclamation point symbol appears to linger longer than a second or two when I start my bike. Sometimes it’s there for 4 or 5 seconds before going off. The yellow triangle is not present. The bike got a full tune-up 4000 miles ago so it doesn't need that.
    The riders manual says this engine symbol plus the yellow triangle means the engine is in emergency operating mode, something I have never experienced. That’s the only thing I see that this symbol is used to indicate, unless I missed something. Otherwise the engine runs as it always did, maybe with and tad more clatter than it did in its earlier age. No fault codes are present according to my GS-911 diagnostics. However, I am wondering if this new behavior is a precursor to some component failure that I’d rather not experience on a road trip. Anybody seeing/experienced something like this?
    Bill in Highlands Ranch, CO
    2012 R1200RT
    Registered User pappy35's Avatar
    Nov 2017
    Collierville, TN
    Have a dealer or someone nearby with a GS-911 scan for codes?
    Oops. I missed that you already scanned it.
    '13 R1200RT 90th Anniversary Edition
    Registered User YeehaStephen's Avatar
    Deep in the Heart of Texas
    My personal opinion... I'm not a BMW tech.
    I don't think you're letting the bike complete it self-diagnosis before hitting the starter button.
    Try turning the key on, let the "Check" symbol come on and then wait till it goes out before hitting the starter button
    I never get the Engine/Exclamation symbol when doing this.
    The only time I get the Engine symbol is when I hit the starter button before the bike has completed it's self check.
    I just went out to verify this before I posted this note to make sure I knew what I was telling you.
    May not be your case, but it's my best guess. Specially since you didn't have any 911 fault codes showing.
    Yeeha! Stephen
    R1200RS, R1200RT, R1200R, (R1150RT = Donated To Charity)
    "Why eat a Burger when you can have Pie?!" Miss Vicki @ Lost Maples Cafe - Utopia Texas
    Jun 2013
    Highlands Ranch, CO
    It worked!
    Thanks Stephen, just went out and tried this and it worked. I just gave it 30 seconds before hitting the starter and voila, no engine symbol.
    Two RT's and 150K miles and I never picked up on this. Thanks!
    2012 R1200RT
    Jul 2015
    Banning California
    Not related. But I have an 07 rt. And my odometer flashs all the time drives nut so I leave on trip meter. Any suggestions on that ???????? JD
    R2007 R1200RT
    3 More years to freedom Retirement LOL
    Old and Tired Gillie Dog's Avatar
    Oct 2017
    Southern California
    Quote Originally Posted by ajaxthegreater View Post
    I read somewhere this also allows the idle stepper motors zero point to be calibrated by the controller. So at each start up they reset to known zero.
    Does anyone know if this is true? I have done the GS 911 procedure but wondered if it was done at each start up automatically also.
    Eric
    (New to me) 2010 R1200RT after HD Electra Glides for 35 years
    Quote Originally Posted by Gillie Dog View Post
    Eric
    Yes - it's true. Put a finger on one of the steppers then turn the ignition on - you'll feel it doing this. It goes to zero then opens to where the ECU thinks it should be to start the bike. The GS-911 zero function simply triggers this. You can monitor the stepper motor(s) position using the GS-911 - how many steps open from zero it is.
    Oct 2017
    Southern California
    Good deal.
    Thank you.
    Eric
    Quote Originally Posted by YeehaStephen View Post
    This is correct I'm sure, but here is some "more to the story."
    If you're riding somewhere and manage somehow to kill your motor, you may be embarrassed or disgusted or whatever and attempt an immediate restart. Probably won't happen. Turn ignition off and back on and go through the wait
    Oct 2017
    Southern California
    Nope, starts right up after killing the engine inadvertently. Pull clutch in and hit the start button and it starts right up, no problem.
    At least on 2010 RT I have.
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    +1
    Same on my 07
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
    Gas gauge always reads full.
    Two weeks I purchased a 2009 R1200GS adventure with 33,000 k on it. Today the info panel began acting up. For a short while the only thing visible was the word PANEL With a yellow triangle, Then panel would then switch back and forth from acting normally to no information. The one constant was the fuel gauge read full. I let the bike go through it start up check.
  1. Run away engine on 2012 R1200RT
    By roy in forum Hexheads/Camheads
    Last Post: 06-15-2018, 02:32 AM
  2. Low oil level warning symbol
    By D.Ed in forum Hexheads/Camheads
    Last Post: 05-23-2016, 11:58 PM
  3. 2013 R1200RT Symbol?
    By xlarry in forum Hexheads/Camheads
    Last Post: 01-10-2014, 09:34 PM
  4. 2010 RT, Function Test- Engine Start Suppression
    By 105258 in forum Hexheads/Camheads
    Last Post: 04-18-2012, 03:43 AM
  5. 2012 RT Engine Guard bracket
    By jeffkyle in forum Hexheads/Camheads
    Last Post: 03-10-2012, 01:55 AM
