Results 16 to 23 of 23
Thread: Breaks up above 1/3 throttle, No fault codes
    Aug 2014
    Virginville, Pa.
    Have all the plastic off at this point so have checked all plugs and all are snapped in correctly. Will check stream tomorrow.
    Aug 2014
    Virginville, Pa.
    Finally found problem. It's a bad connector on the coil. I had both top coils laying on the cylinder heads with other plugs in and engine running watching the spark on both sides. I picked up left side coil to move it and spark disappeared. Wiggled the wire and it came back. That's why problem came and went. I looked at these suckers before but I guess when I put it back in it moved the wire just enough to lose contact. Don't know if I can repair this connector, it looks pretty fragile. Wonder where I can get a new one on a Sunday. Maybe a standard automotive part?
    Mansfield,MA
    Crazy
    Mod Squad
    2009 F800GS 1994 TW200
    Aug 2014
    Virginville, Pa.
    After cleaning it with contact cleaner and a close inspection this plug is shot. The plastic is cracked and all 3 pins are corroded through. Looks like the rubber seal was damaged and water got in there rotted the connectors. Don't know if BMW will have a replacement plug or not. Wonder if I could get one from someone who parts out wrecks. Any ideas?
    Central Ohio
    Part #83 30 0 402 341, I think, from your dealer or Max BMW:
    Call before going to your dealer, they will probably need to order it.
    Other than headlight bulb connectors, I've had no luck finding BMW electrical plug$ anywhere but a dealer.
    Somebody prove me wrong....please.
    Larry
    2006 R1200RT
    Aug 2014
    Virginville, Pa.
    On Hermy's BMW website it says part no longer available. But it shows on the Max BMW site. Will have to wait till Tuesday to find out who has it or not. Damn, I really need to be in Southern Michigan Saturday morning for a friends memorial. With shipping time, if anyone has it, going to be cutting it close. I did send beemer boneyard an email to see if they had any old harnesses lying around. They have always done me right. We'll see. Oh yea, and Florence did my GPS in too. Waterproof my ass. Been a fun week. Can't wait to see what this week has in store for me. As long as I'm sucking air it's all good.
    CENTEX USA
    Glad you found a cause, hope you can source that plug
    Steve Henson-Mod Team and club tire changer
    Aug 2014
    Virginville, Pa.
    Yes, thanks to all for the help. I looked at that plug in the beginning of this but I only looked at the end and the little terminals in there where clean and shiny. The problem was just below the rubber seal. It was cracked and the water got in there and corroded the ends of the terminal where the wires attach. It's almost always something simple.
  1. 2016 R1200RT - fault codes
    By mauricedonini in forum Wetheads
    Last Post: 09-13-2016, 01:10 PM
  2. GS-911 Fault Codes (2002 R1200C)
    By rocketmanli in forum Oilheads
    Last Post: 12-01-2011, 10:20 PM
  3. GS Fault Codes?
    By phred737 in forum Hexheads/Camheads
    Last Post: 08-04-2011, 05:56 PM
  4. fault codes / computer
    By samuelh in forum Motorrad
    Last Post: 06-19-2011, 10:19 PM
  5. Fault Codes
    By mpmarty in forum Hexheads/Camheads
    Last Post: 09-10-2010, 03:06 AM
