Results 1 to 10 of 10
Thread: Front axle shaft Lube
    Dec 2007
    Indiana
    Front wheel off for new tire. Need a little lube on axle...what's recommended?
    2018 RT
    MOA #46783
    '99 '03 '06 National Co-Rally Chair Friedle's Avatar
    Poughkeepsie, NY
    Wheel bearing grease works fine on the surface of the axle before reassembly. Avoid Red Loctite for this step.
    Friedle
    Ride fast safely
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    All you are trying to do is prevent the axle from rusting and becoming difficult to remove. A thin film of any automotive grease will do the job.
    Kevin Huddy
    Mansfield,MA
    I added a bit to your title as it will make it easier to help others find the information.
    I will move this to HEX/CAM later.
    Mod Squad
    2009 F800GS 1994 TW200
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Yep, I just use whatever is handy.
    Lee
    2016 R1200RS
    MOA # 30878
    Liaison 20774's Avatar
    YMMV, but I've never put anything on any of the axles I've reinstalled in my bikes. In fact, I tend to wipe them down a bit.
    Dec 2007
    Indiana
    Thank you!
    2018 RT
    MOA #46783
    Assuming this is a newer bike with sealed bearings, you might in addition want to pack some of the "any NLGI #2 grease will do" grease around the outside of the wheel bearing seals before you put the axle spacers on as an extra deterrent to water getting at the seals of the sealed bearings.
    Lee A. Dickinson - Danielsville, GA USA
    Airheads #3480 | Iron Butt Assn. #8914
    1992 R100RS - 1993 K1100RS - 2013 R1200GS
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    As recommended in the BMW RSD DVD I use Castrol Optimoly Paste TA
    or Honda Moly 60
    You can get it from:
    https://www.motobins.co.uk/
    or
    https://www.5150motorsport.com/castr...43-305-08.html
    Apparently the Honda Moly 60 has been discontinued
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
    I've always used anti-seize lubricant. Can't remember why, but never had any problems.
  1. Front axle foolin'
    By Jinxman69 in forum Airheads
    Last Post: 04-15-2016, 01:37 PM
  2. Front Axle
    By 92r100rt in forum Airheads
    Last Post: 09-19-2009, 01:46 AM
  3. Front axle
    By 31310 in forum Hexheads/Camheads
    Last Post: 07-25-2008, 06:33 PM
  4. need help on front axle spacers
    By mrocket49 in forum Airheads
    Last Post: 06-05-2007, 01:13 AM
  5. 14 vs 17 mm front axle
    By markst1 in forum Airheads
    Last Post: 10-17-2005, 05:44 PM
