Results 1 to 14 of 14
Thread: fuel pump recall
    Registered User kthflieger's Avatar
    Apr 2011
    Prescott AZ
    fuel pump recall
    Picked up a new (to me) ride a few weeks ago - a 07 1200GS. The ride home went all the way down the eastern seaboard. Toward the end I noticed the smell of gas, but not real strong. Parked the bike and came back to it a few days later. Started it up and watched the pump spray fuel all over the left side of the fairing and engine. Sure enough, the parts replaced 2 years prior as part of the recall had split again. This time it was the threaded fitting in the top of the fuel pump.
    The pump was fine and after some digging I found the aftermarket kit at the Beemerboneyard. Instead of $$$$ for garbage plastic OEM parts, they have a chrome plated brass fitting kit that replaces the quick disconnect on top of the pump, both male and female ends as well as the quick disconnect at the bottom of the other side of the tank and all for only $75.
    Simple, easy and inexpensive with better than OEM parts.
    So much for the E.U.s mandate to make all those parts recyclable. Instead of really researching reliable compounds, the manufacturers just used the first products that they came up with and now they can keep re-selling limited life products. It's not just a BMW Motorrad problem. Their cars as well as VW and MB all have the same issue with decaying brittle plastic critical parts...... but I digress
    Cudos to the guys at Beemerboneyard
    "Wer reitet so spaet durch nacht und wind -es ist der Vater mit seinem Kind" -- Goethe
    R1200RT, F800GS
    '80 GL1100
    Frieden mit uns allen drummer's Avatar
    Oct 2006
    Hillsborough, NC
    Good to know - the two years on my replaced parts is coming up.
    05 R1200RT
    Duragloss, Sidi, Russell, Olympia, Arai
    Sonor Signature Series (no longer made thanks to AMF buying Sonor)
    These are a few of my favorite things ...
    Aug 2014
    Lakeland,FL
    So a new fuel pump installed by a BMW dealer last year still suffers from the same type of potential failure? They didn't redesign them to fix the problem? I ask because I had no choice when my failed on the road as I started a three week cross country trip.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by kthflieger View Post
    The female half of the quick disconnect?
    Lee
    2016 R1200RS
    MOA # 30878
    May 2007
    Western NY
    So you're going to screw a metal fitting into a plastic flange. The fitting won't break, but if you over-tighten it, the flange will most probably crack.
    Karl
    2007 R1200ST
    AZ
    The flange will crack if you over torque it. BBY supplies some fuel resistant thread dope that is supposed to seal it up without the need to over torque it. However, The female thread in the top of the fuel pump assembly is tapered and is plastic. It is very easy to crack it by threading in a metal quick disconnect fitting. If yours is already cracked, then you will need to replace the fuel pump assembly, not just the quick disconnect fittings. Sorry, BTDT.
    MOA #107139
    RA #28511
    May 2003
    SW Iowa
    Quote Originally Posted by kthutchinson View Post
    So you're going to screw a metal fitting into a plastic flange. .
    When I replaced the fuel disconnects on our K1300Ss I decided to only replace the male half.
    I was worried about cracking the plastic fuel pump flange if I installed the metal female half.
    I did the Beemerboneyard fix before the recall.
    Lee
    2016 R1200RS
    MOA # 30878
    Apr 2011
    Prescott AZ
    The fix the BMW engineers crafted, molded a metal ring around the female threads on the top of the fuel pump, thus making the top of the fuel pump a little more resilient. What got brittle on mine was the factory nipple (also replaced as part of the recall) that threads into the top of the pump. That is the part I replaced with the Beemerboneyard kit. Of course over torqueing can be an issue, so don't over torque that fitting and use the kit included thread sealant!!
    R1200RT, F800GS
    '80 GL1100
    Apr 2011
    Prescott AZ
    This was the kit I ordered, but they have other variations.
    https://www.beemerboneyard.com/cpcqkdisconr12.html
    R1200RT, F800GS
    '80 GL1100
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    Was the pump replaced or did they only installed a reinforcement ring on the old one?
    They only installed a ring on mine at the time and it started leaking last fall.
    I brought it back to the dealer and BMW replaced the fuel pump with a new one.
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2019 R1250RT - 2007 R1200RT (186,000 km) - IBA # 56396
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    Quote Originally Posted by azgman View Post
    I did mine recently, the lower female and you have to use good judgement. The directions say half turn, I stopped at a quarter. It's been fine so far The threads weren't cracked, but it looked like whatever dope Victory BMW used when reassembling it when putting in that ring had dissolved and it was pissing out. I decided to put the metal one in anyway and replace the o-ring again.
    My Motorrad Blog
    My Motorrad YouTube
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
    Registered User jcdas's Avatar
    Jul 2015
    Sarnia, ON
    I bought my 2011 RT in 2014 from Toronto BMW. At the time the 'repair' was done under the recall.
    Last year I started to smell fuel. I thought it was the other cars in traffic.
    This spring it was really smelling bad, so I took off the plastic and found the fuel pump well was soaked in raw stale gasoline.
    I followed up with Grant the Service Manager at Wolfe BMW in London, as I now live in Sarnia Ontario. Grant followed up with BMW Canada who agreed to replace the fuel pump under 'goodwill'.
    After a bit of a wait to get a service appointment, I brought the bike in and they replaced the fuel pump at no cost to me.
    Hopefully this fuel pump is made of better materials that can handle whatever is cracking the plastic. My guess is Ethanol!
    Kudo's to Wolfe BMW for going to bat for me with BMW Canada, even though I didn't buy the bike from them. I'm happy with Grant the service manager, and the new owner Mark Minnie.
    John Das
    Sarnia, ON
    2011 R1200RT
    Fuel leak
    You should also consider replacing the OEM plastic fuel connection fittings, adjacent to the pump, with higher quality chromed, brass units from Beemer Boneyard. My 2011 started leaking at around 30k mileage on a trip thru Wyoming and Montana, over the Bear tooth Highway. Parts kit runs about $70. And takes about an hour. I did my own...
    Sep 2009
    Chestnut Hill, MA
    1/24/2021 - Here is a link on the NHTSA website to the latest recall letter which BMW is sending out: https://static.nhtsa.gov/odi/rcl/202...0V471-4061.pdf
    John Gamel - BMW MOA Consumer Liaison 2018-Present
    2015 Ebony Metallic R1200RT
    MOA #153274
    "We have met the enemy and he is us." Pogo-via Walt Kelly
  1. Recall is on- fuel pump flange/fuel pump
    By David13 in forum Motorrad
    Last Post: 10-25-2018, 10:15 PM
  2. Fuel Pump recall question
    By Texpaul in forum Hexheads/Camheads
    Last Post: 06-04-2015, 09:48 PM
  3. Fuel pump recall??
    By gene36542 in forum Hexheads/Camheads
    Last Post: 04-29-2014, 04:27 PM
  4. Finally a fuel pump flange recall
    By mpmarty in forum Hexheads/Camheads
    Last Post: 01-08-2014, 02:59 PM
  5. Fuel Pump recall
    By BMRUP in forum Oilheads
    Last Post: 04-09-2005, 12:05 AM
