Results 1 to 8 of 8
Thread: Questions about Skene P3 lights wiring
    Sep 2013
    Toronto, Canada
    Trying to wire my Skene P3 lights to the 2017 RT license plate bracket. Any suggestion or pics on how to run the wire as concealing and elegantly as possible?
    On my 2012 RT, I could easily run the wire under the gaps of the rear light assembly with the wire poking through the little hole right behind the license plate. With the 2017 (or any water cooled RT I suspect), the rear wheel wheel appears to be tight with no obvious holes or gaps.
    I welcome suggestions and pics.
    Sep 2009
    Chestnut Hill, MA
    Kevin - I've installed Skene P3 lights on my now-former 2008 RT and on my 2015 RT. On the latter bike, I don't recall exactly how I routed the wires to the right place. That said, I think I drilled some very small holes through the plastic fender and routed them up to a power source. I'll take a look tomorrow (5/30), make some photos and post or send them.
    John Gamel
    John Gamel
    2015 Ebony Metallic R1200RT
    BMW CCA 2006 - Present; BMW MOA 2009-Present
    Walt Kelly: "We have met the enemy, and he is us."
    Oct 2017
    Reno, NV
    Kevin, I have Skene P3 on my 17 RT. I drilled a small hole behind the license plate (green arrow shows approx position) and ran both wires through that hole and up towards the rear seat. I secured the wires to the underside of the mudguard using Gorilla Tape (not perfect, but so far it has held fine for a few thousand miles). II got the wires from under the mudguard up into the area under the rear seat where my HexEZCan is by threading them through the plastic where the red arrow is. If you look closely, you can see the wire (covered in electrical tap). I did not have to remove any of the plastic to thread the wire through there, as I recall it was an easy task to push the wire through and grab it from above.
    Hope this helps.
    2017 R1200RT
    2016 Honda Africa Twin
    Sep 2013
    Toronto, Canada
    Quote Originally Posted by tmac99 View Post
    Excellent tips TMAC! I was also wondering about the best way to manage the wire. I have considered using Shoe-Goo or something like that...
    Mar 2011
    socal
    Kevin
    I also drilled a small hole in back of license frame and same for bottom tray under rack
    Enclosed the wires in shrink tubing and used a dob of Black silicone sealant to fill around the holes
    No issues in 10’000 miles
    If you haven’t already purchased your P3 lights, take a look at Clearwater lights “Billie brake light” along with there CANopener version 1.82 a more expensive option, but in my estimation a better product, and I’ve installed over a dozen sets of Jerry’s P3 lights without any issues
    Jim
    Sep 2013
    Toronto, Canada
    Quote Originally Posted by t6pilot View Post
    Thanks Jim. I like the shrink tube idea. However, how did you stick it to the wheel well?
    I’m actually transplanting the P3 lights from my 2012 (sold) to my current ride. Also looked at the Clearwater, but I read that the lights are not as bright as the P3s...
    Mar 2011
    socal
    Kevin
    I didn’t need too the the hole in the bottom tray or shelf is almost vertical from the license bracket, I used a piece of coat hanger wire to snake the P3 lights power wires forward, by the way my lights had previously lived on a 1200gs and a 1600gt
    Jerry has a quality product that lasts along time
    Oct 2017
    Reno, NV
    Quote Originally Posted by kevinsclo View Post
    Kevin - I just used some Gorilla Tape (aka fancy duct tape), but I like the shoe goo idea - that may work better in the long run.
    2017 R1200RT
  1. Replies: 1
    Last Post: 09-11-2015, 02:54 AM
  2. Skene P3 Lights on a 2014 RT
    By indawin in forum Wetheads
    Last Post: 05-22-2014, 03:07 PM
  3. Wiring LED Lights
    By brittrunyon in forum Airheads
    Last Post: 10-03-2013, 10:32 PM
  4. Replies: 17
    Last Post: 12-19-2011, 02:48 PM
