Results 1 to 5 of 5
Thread: Hex nut size
    Oct 2017
    Wesley Chapel, FL.
    Hex nut size
    1994 R100RT... Iím replacing the fork springs. Can any one tell me the size of the Hex nut on the fork tubs.
    Liaison 20774's Avatar
    If memory serves me, it's 36mm...that's what my /7 is. It's either that or 27mm. Easy enough to measure across the flats with a ruler...you'll know what it is.
    The older bikes had a sheet metal wrench in the toolkit that fit those nuts.
    Since the newer bikes have K-bike forks, the size may be different.
    Registered User AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    I think they are 41mm.
    Anton Largiader 72724
    Tech articles - YouTube
    Virginia Motorrad Werkstatt BMW motorcycle service and repair in central Virginia
    Oct 2017
    Wesley Chapel, FL.
    It is 41mm. Thank you for your input.
