Results 1 to 15 of 15
Thread: Valve Service Time
    Left Coast Rider
    Valve Service Time
    Any idea how long a valve check / adjustment should take, from roll-in to fairing back on, for a K1200S? I understand that the more valves which need adjustment the longer it will take.
    Thanks in advance for your input.
    Debbie's Servant Lee's Avatar
    SW Iowa
    On our K1300Ss we were charged 2.7 hours to check the valves, replace the plugs and change the coolant.
    No adjustment was needed at 30,000 miles.
    How many miles on your S ?
    Lee
    2016 R1200RS
    MOA # 30878
    SW Iowa
    The cams need to be removed if you need an adjustment.
    Once the cams are out, it may not be a big difference if one or three valves need adjustment.
    Lee
    2016 R1200RS
    MOA # 30878
    Left Coast Rider
    40,000 miles. Valves were last checked / adjusted at 25,000. Might I be wasting time and money to have them checked now?
    SW Iowa
    I'm surprised they needed adjustment at 25,000 miles.
    Since they were out of spec at 25,000 miles it would be good to check them at 40,000 to 43,000 miles.
    Lee
    2016 R1200RS
    MOA # 30878
    Left Coast Rider
    There were two valves needing to be brought into spec. I thought that was pretty good.
    SW Iowa
    Not always, but in most cases, K bikes go a long time before a valve adjustment is needed.
    I don't know how much time is added if any shims need replacement.
    I'm going to guess another hour.
    henzilla can probably tell you.
    Lee
    2016 R1200RS
    MOA # 30878
    Left Coast Rider
    I appreciate the info, Lee.
    Sep 2016
    Louisville KY
    Lee, was that at a BMW dealer (flat rate for the work or actual time charged)???
    SW Iowa
    Quote Originally Posted by dynajohn View Post
    The work was done at a BMW shop, Engle Motors in Kansas City.
    I think it was flat rate. Seems like the bill was pretty close to the estimate they gave me.
    Lee
    2016 R1200RS
    MOA # 30878
    Sep 2016
    Louisville KY
    I go to my dealer every Saturday to BS with friends. I will check what the estimate for valve check, coolant flush & plug change. I would gladly pay for 3 hours for this service plus parts. Valves on modern motorcycles seldom need adjustment at 30,000 miles, a far cry from the 1970's & 1980's when valve seats seemed to be made of peanut butter.
    Left Coast Rider
    Had valves checked. I brought the bike in sans fairing. Nothing needed adjusting. One and a half hours labour including plug change. Seems about right considering they didn't have to deal with any bodywork.
    Sep 2016
    Louisville KY
    5hrs was what my local dealer estimated for labor. That's to check valves, change plugs, change coolant. $440.00 includes Tupperware removal & reinstall.
    Registered User radiofun1's Avatar
    Dec 2009
    Helena, Montana
    Good idea to take the plastic off. I'll remember that.
    Sep 2016
    Louisville KY
    Quote Originally Posted by radiofun1 View Post
    I agree, probably knock off 1 hour which I can do myself
  1. rate of valve wear over time on 87 K75
    By 48882 in forum Flying Brick K-bikes
    Last Post: 07-10-2011, 04:29 PM
  2. Borrowed time on valve train?
    By ohiorider in forum Airheads
    Last Post: 11-17-2009, 06:36 AM
  3. R65 head & valve service
    By captbilly in forum Airheads
    Last Post: 05-06-2007, 01:35 AM
  4. valve cover gaskets need 2 replace every time?
    By nhlkats in forum Airheads
    Last Post: 01-02-2007, 10:27 PM
  5. K75 valve adjustment time????
    By chrismiii in forum Flying Brick K-bikes
    Last Post: 10-09-2006, 08:01 PM
