Results 1 to 5 of 5
Thread: HELP ON BRAKES R 2012 RT Camera Head SPONGY brake SUCKING SOUNDS
    Der Kaptain mrtnfischer's Avatar
    Dec 2008
    Moscow, NE PA near Scranton
    Cool HELP ON BRAKES R 2012 RT Camera Head SPONGY brake SUCKING SOUNDS
    OK< I read all the posts, Have a spongy front lever for the 2012 ABS system , decide to bleed rear.
    so did it normal, Nothing comes out of the rear, Pump, close, pump, close, etc.
    So I put a clear hose over the bleeder valve loosened it, pumped sucked, closed, pumped sucked close, some fluid came out and lotssa bubbles, than no fluid (from the bleeder holes, I think)......I should be getting fluid, nothing coming out...BOY was my wife laughing at me while she pumped...NOT FUNNY SAYS I..Ha says she..
    ARRGH What is going on no fluid means no brakes in the rear, I have not taken it out on the road yet, but the light was NOT ON BEFORE.
    suggestions please. HEY Maybe I have to use the rear brake peddle??? instead of the front lever
    Old and Tired Gillie Dog's Avatar
    Oct 2017
    Southern California
    Quote Originally Posted by mrtnfischer View Post
    I will assume that is a joke.
    "Standard method" will work fine but it is nice to also get any bubbles out of the ABS block also with a GS911.
    For rear I:
    Pulled caliper and blocked caliper pistons back/in.
    Cleaned out resevoir to just a couple drops left.
    Fill with new DOT4 and keep mostly full as it goes down
    Press down peddle open bleeder, close bleeder
    Repeat until clean fluid comes out.
    Then I did GS911 procedure but could have done that in middle of sequence.
    I had just changed a leaking master cylinder so I got out some bubbles.
    Speed bleeders are nice for old guy like me, makes it much easier.
    Did same for front.
    GD
    (New to me) 2010 R1200RT after HD Electra Glides for 35 years
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    Check to see if the brake line is not twisted under the rear fluid reservoir.
    I don't know if it's different on the 2012 but on my 07 the reservoir tends to turn a little in the holding clamp when you tighten the cover.
    I you don't pay attention to it, eventually, the brake line becomes twisted to the point where the fluid cannot go through anymore.
    DAMHIK
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
    Dec 2008
    FIXED the problem, For some reason, LINKED NOT
    OK well the front brake system and the rear are separate, I was pumping the front brake lever and trying to bleed the rear (super dumb)
    I found the reservoir under the seat..Problem solved
    Than it was easy to do the front, all is good now, thanks
    Oct 2017
    Southern California
    They are linked.............................
    Electronically
    Not physically.............
    Good it worked out well.
    GD
  1. Spongy brakes, need advice on remedy, 2007 RT
    By rthump in forum Hexheads/Camheads
    Last Post: 05-02-2017, 03:29 AM
  2. 600 service = head torque ? 2012 R1200GS
    By maxscycle in forum Hexheads/Camheads
    Last Post: 06-12-2012, 05:02 AM
  3. Touratech Cylinder Head Guards 2012 R1200RT
    By bigwaves in forum Hexheads/Camheads
    Last Post: 04-17-2012, 02:51 PM
  4. 95 1100r spongy brake lever
    By hmdalton in forum Oilheads
    Last Post: 02-27-2012, 02:49 AM
  5. spongy front brake
    By BILLWEIDNER in forum Airheads
    Last Post: 06-25-2010, 12:16 PM
