I've begun to disassemble the R90S. Started with the master cylinder. It's clean and ready to be sleeved and rebuilt. I planned to rebuild the disc brakes but ran into a problem. The bolts holding the units will not budge and it appears that someone put a wrench to one of them and damaged the bolt head. I was told by a Harley friend to use lots of heat from a torch but dont want to make the problem worse. Any ideas on how to safely remove the bolts? Many thanks in advance.
