Hi everyone- I have a leaking front cam seal that's dripping oil onto the points - also read Brooke Reams thread on replacing a leaking camshaft seal behind points / timing plate
In his pictorial, engine is removed from frame.
Can this be done with engine in frame?
Thank You
I did the one one on my /7 that way. If the seal puller doesn't work, you can carefully drill a small pilot hole and then drive a small screw into the body of the seal. Then pull the seal out with a pair of pliers. Mine came out pretty easily.
I've never owned this tool, but the way I understand it, you remove the advance unit leaving just the points and rubbing block. The rubbing block rides on the eccentric part of the advance unit...it has high and low spots. With this tool, you don't need to worry about where to turn the engine to find the high spot, or find the S-mark, etc. The tool creates a "high" spot at any position. You just set the points, pull the tool, then reinsert the advance unit.
This all works well if...if...everything is to spec. The approach is to set the gap to the nominal 0.016" (from memory) and then begin to set the timing so the points open at the S-mark. If the timing is advance or retarded, then the process is to rotate the points plate to get the proper timing. But what if you rotate the points plate but can't rotate it far enough to get the proper timing? The botch job approach is to open up the slots in the points plate. You can bet the factory would never have done that!
The way around this situation is to change the points gap to something other than the nominal. A small change in points gap makes a big change in the time of points opening. The gap can be a wide range, something like 0.012 to 0.022 and the bike will run fine. The only time the gap is critical is on many multi cylinder engines like 6- or 8-cylinders. The gap...or in reality the amount of time the points are closed...defines the amount of time the current is flowing to the coils to saturate them before the points open. When they open, the field collapses and the spark is generated at the plug. So, don't be afraid of changing the gap to something other than nominal if the situation calls for it.
