Results 1 to 15 of 16
Thread: 2007 R1200GS - Spins but won't start
    Registered User bobmorse's Avatar
    Aug 2004
    Massachusetts
    I have a 2007 R1200GS with less than 2,000 miles on it. The past few years, it has only been ridden 20 miles or so to get its annual inspection. Went to fire it up in preparation for May 31st annual inspection due date, and to post the bike for sale.............Everything lights up as expected, engine spins rapidly..........doesn't fire. Battery has been on a battery tender all winter, bike has fresh gas. The only "error" messages are for low fuel, and brakes. I think both of these only reset when I run the bike.........which I can't.
    Can anyone advise this old phart where to look first to solve the problem at getting this bike running, inspected, and hopefully sold?
    Thank you for your guidance.
    /Another Bob
    Registered User dirtmerchant's Avatar
    Feb 2006
    Southwest Florida
    I think I'd check plugs to be sure you have spark, if so I would then look at the fuel pump.
    AZ
    Yep, I agree, check to see if the fuel pump is working. Most likely it is the fuel pump controller; an easy fix.
    MOA #107139
    RA #28511
    Quote Originally Posted by azgman View Post
    Easy, not cheap....
    Aug 2004
    Massachusetts
    Thanks for your suggestions
    I'll take a look and get back to you.
    /Another Bob
    AZ
    I think the fuel controller is about $150... that's about as cheap as a repair can get!
    MOA #107139
    RA #28511
    Registered User ajaxthegreater's Avatar
    Jun 2013
    Highlands Ranch, CO
    If the fuel pump is working you should be able to smell unburned gas at the exhaust pipe outlet after you've cranked it over for a minute or two. If not I'd suspect electrics, like spark.
    Bill in Highlands Ranch, CO
    2012 R1200RT
    Aug 2004
    Massachusetts
    I'll add that to the list of things to check
    Thanks, Bill. I'll get my sniffer ready to check it in the morning.
    /Another Bob
    Spring Lake NJ, USA
    An engine needs 4 things to run:
    1. fuel to burn
    2. ignition to fire off the fuel
    3. oxygen to combine with the fuel and make a burnable mixture
    4. someplace for the resulting waste products to go
    The most likely reasons for it not firing are #1 or #2. Unless you've blocked the intakes somehow - it has #3, ditto on #4 (I did have a friend who once corked up the exhaust on his GS to wash it - and forgot to take the cork out.. it wouldn't start.)
    Ignition failure is actually a rather remote item since there are two coils and two plugs in each cylinder. Chances are one of them out of the 4 would be working and at least you'd get a "bang" out the exhaust.
    So - that leaves fuel. Simple to check - pull one of the plugs. If the fault was ignition and fuel was reaching the cylinder - the plug and top of the piston would be wet with fuel. Not wet? Means there is no fuel getting there. Could be injectors or the pressure regulator - except these almost never fail. What does fail - especially on some models where the pump controller is mounted so it collects water - is - the pump controller.
    Pull a plug. Dry as a bone? Chances are it's the pump controller causing that - especially if it's the original one on an '07 GS.
    Mansfield,MA
    racer7 gave us a really nice tutorial on fuel pump controllers- https://forums.bmwmoa.org/showthread...wanted-to-know
    Mod Squad
    2009 F800GS 1994 TW200
    Old and Tired Gillie Dog's Avatar
    Oct 2017
    Southern California
    They do die.......
    My fuel pump controller died yesterday way out in the boonies on a USFS paved road through the "forest". I pulled over under a shade tree and tried to start several times, no love. Said some swear words....
    Thanks to all the information here on this site about the likely hood of this failure I had the prerequisite GS911 and cell phone, Burns Moto bypass cable and tool kit with me. (also carry air pump and tire plug kit) GS911 said fuel problem, most likely fuel pump controller. Took of fairing, fuel pump well was very clean and dry, screws on controller were shiny. Pulled controller and sure enough underneath was about 1/3 filled with water, o'ring seal was not installed properly and pinched off to side leaving opening for water. Water must have been there many months because as the second owner I have never washed this scooter. Installed bypass, hit start button and instant start....... Put it back together, plugged in bypass and road the 75 miles to dealer I pass on the way home and they had one in stock, surprise, surprise. $226.04 plus tax. (I bet they install them regularly.) Went another 40 miles home, installed new controller and instant start just like with bypass.
    Not a good day.....................
    Stupid me I did not look under controller a couple months ago when fairing was off but the fuel pump well was clean and dry. Live and learn.
    Eric
    (New to me) 2010 R1200RT after HD Electra Glides for 35 years
    Aug 2004
    Massachusetts
    Thanks for the tips
    Thanks Don and others.
    Will try to get out there today and look further.
    /Another Bob
    Registered User Coma's Avatar
    May 2015
    Emerald Coast
    Blog Entries
    Thumbs up
    Thank you gents!
    Very timely for me. I am doing my annual and added this inspection to my list. I've a trip scheduled for mid summer. My connections are in good shape, although I do wash my bike at least monthly. The controller is in good shape, too. The Burnsmoto bypass is to be delivered today.
    2008 R1200GS
    Aug 2004
    Massachusetts
    Bike wouldn't start - RESOLVED
    I gave in and had Max BMW of New Hampshire retrieve the bike. Along with some of last Fall's fuel having left a nice varnish, the fuel pump had died. Fixed under warranty, and also caught the bike up on open recalls. Bike was returned to it's new owner within a week, runs fine. Thanks for input from all on this forum, and to Max BMW.
    Dec 2007
    Indiana
    Quote Originally Posted by bobmorse View Post
    Didn't realize they're extending warranty on this fix so far out...11 years! Good to know.
    2018 RT
    MOA #46783
  1. 2007 R1200GS Cold Start Rattle
    By v1ct0r in forum Hexheads/Camheads
    Last Post: 10-13-2014, 08:01 PM
  2. 2007 R1200GS Won't start
    By Telebeamer in forum Hexheads/Camheads
    Last Post: 10-07-2012, 09:55 PM
  3. Oil filler cap just spins
    By gharlow in forum Oilheads
    Last Post: 09-08-2009, 08:02 PM
  4. trip mileage reset SPINS
    By cptss67 in forum Oilheads
    Last Post: 05-15-2009, 05:04 AM
  5. Starter spins but won't engage
    By Scotty2 in forum Flying Brick K-bikes
    Last Post: 05-19-2008, 02:35 AM
