Results 1 to 2 of 2
Thread: 05 R1200RT- Issue With Garmin 550
    Canberra,Australia
    For some years, I have had a Garmin 550 permanently wired in to the BMW Sat Nav connector plug taped to the headstock on my 05 RT. No problems
    Recently I acquired an Optimate charger, the model with the CANBUS selection setting.
    The Optimate turns on the Garmin 550 while its charging. I can turn the Garmin off with the rubber button on the Garmin unit, but it tuns on a few minutes later.
    So, I have questions :-
    1 Why is it so
    2 Is it a drain on my battery
    3 Can I stop the Optimate switching on my Garmin 550
    DabDab
    Australia
    If off, the Garmin comes on as soon as "new" power is supplied, as if it is just plugged in. So the Charger and Canbus have no power to the GPS but then supplies power to that circuit - which causes the Garmin unit to turn on. That is the why. How to fix it is your choice. I would install a new outlet directly to the battery and let the charger ignore Canbus entirely.
  1. Replies: 15
    Last Post: 11-01-2016, 08:38 PM
  2. Garmin Montana 600 Issue
    By sickticket in forum Gear
    Last Post: 07-12-2015, 12:45 PM
  3. Garmin Zumo 660LM Fuel Gauge Issue
    By ralphmccomb in forum Gear
    Last Post: 08-08-2013, 09:09 PM
  4. Garmin 665 /GXM40 issue
    By dbaliko in forum Gear
    Last Post: 10-02-2010, 09:03 PM
  5. Garmin 276c power/audio cable issue
    By Fatthumz in forum Gear
    Last Post: 02-28-2008, 11:49 PM
