I have a 92 K75 with 30,000 miles. A month ago, I took apart the ignition switch and cleaned it and replaced.
I replaced the battery with a smaller one (my error) but the bike still started and ran. About 20 miles out, the starter motor started running so I shut the bike off and was able to disconnect the battery before the starter motor burned up. Online, I find out the starter relay welded shut due to low voltage.
Ordered a new battery and relay and installed. My battery charger was lent out so I just hit the starter button. The bike ran for about 2 minutes, the red battery light came on and . . . the starter motor started spinning. Disconnect battery. It had a 12.6 voltage.
Ordered 2 relays, and installed one with fully charged battery @ 13.6 volts.
Hit the starter, bike started and 10 seconds later the red battery light came on but I shut the bike down ASAP. Battery voltage down to 12.6 volts.
Any ideas?? Alternator?
