Results 1 to 10 of 10
Thread: 2008 GSA shutting down completely when going from 1st to 2nd
    Apr 2017
    Winston Salem, NC
    Has anyone ever experienced their GSA shutting down completely when going from 1st to 2nd ?
    It has happened at random times, but yesterday it happened just after I gassed up and while trying to take off at an intersection.
    Not a good time for it to shut down, but it restarted just fine and it didn't do for the remainder of our ride.
    I posted this to the BMW R1200GS Owners Facebook forum and got some suggestions:
    • Ignition Switch could be faulty
    • Side Stand Switch could be faulty
    • Weak battery or battery requires charging (8 months old, kept on trickle charger when there are extended periods of non-riding, ruled that one out)
    I did bypass the side stand switch in the hopes of narrowing down the issue. Was able to disconnect wires from the switch and kept them fully intact to include the terminal ends.
    It's a 2008 GSA. Any other thoughts as to what it could be and/or what else to investigate?
    Dave
    2008 1200GSA
    MOA# 213524
    Past Bikes: BMW F650CS (for sale)
    Apr 2017
    Winston Salem, NC
    Hmmm.....
    Nothing, nada...crickets ?
    Dave
    2008 1200GSA
    MOA# 213524
    Mansfield,MA
    Did you check for codes? Either a GS911 or at the dealer?
    Mod Squad
    2009 F800GS 1994 TW200
    Oct 2007
    Covington, LA
    Iíve had this happen. I have an 08 GS. Same description. Happened several times after getting gas. My issue was I slightly overfilled the gas tank and gas went into the canister. Since you said you just got gas, Iím guessing itís same thing. Unbeknownst to me at that time, this is a common issue. Google canisterectony adv and youíll get some solutions. I just stopped overfilling the tank and issue never reoccurred.
    Good luck!
    Greg
    Apr 2017
    Winston Salem, NC
    Omega Man,
    That was next on my list. I can have the dealer check the codes, don't know anyone with a GS911.
    Dave
    2008 1200GSA
    MOA# 213524
    Apr 2017
    Winston Salem, NC
    Quote Originally Posted by beckgr View Post
    Good luck!
    beckgr,
    Every time the bike has shut down it's been at very random times, no situation has been the same. I've filled up this bike dozens and dozens of times, but this was the first time it happened after a fill up. I can count on one hand the number of times the engine shut down, but none of the situations are similar.
    Dave
    2008 1200GSA
    MOA# 213524
    Dave,
    You might want to browse through: https://forums.bmwmoa.org/showthread...oradic-starter - and look at what the cause was. Could it be? Mebbe.
    Apr 2017
    Winston Salem, NC
    Dave,
    Thanks Don!
    Interesting. I'll experiment with which way the front tire is facing while trying to start the bike.
    Dave
    2008 1200GSA
    MOA# 213524
    Apr 2017
    Winston Salem, NC
    Definitely something electrical
    Dave,
    Played around with starting the bike last night and I'm convinced it's electrical. Started just fine, but head lights were flickering, taillight acting as if I was cycling the brakes, turned on the high beam and then it quit. Instrument panel went blank, no power.
    Battery terminals tight and clean. I did not check the battery ground, but it was suggested by a co-worker who had a similar issue.
    I'll check it out after work.
    Dave
    2008 1200GSA
    MOA# 213524
    Apr 2017
    Winston Salem, NC
    Quote Originally Posted by dsdragt View Post
    Does anyone know where the battery ground is located ?
    My research has found that it's under the gas tank, attached to the left side of the motor, near the alternator ?
    Does that sound right ?
    BTW... I have a 2008 model
    Dave
    2008 1200GSA
    MOA# 213524
  1. Completely disgusted with BMW
    By Motodan in forum Wetheads
    Last Post: 06-17-2014, 06:13 PM
  2. france-completely-paralysed-by-almost-100000-bik
    By moondog59 in forum Campfire
    Last Post: 06-29-2011, 02:29 PM
  3. ...and now for something completely different...
    By ultracyclist in forum Regional Midwest
    Last Post: 05-19-2010, 05:37 PM
  4. Replies: 6
    Last Post: 03-13-2010, 02:58 PM
  5. completely useless, but i don't care..........
    By BUBBAZANETTI in forum Gear
    Last Post: 03-18-2005, 01:01 AM
