Results 1 to 5 of 5
Thread: Nav iv dead
    Nov 2017
    Belmont, NC
    Nav VI dead
    On a ride my Nav VI just stopped working! Black screen as if powered off, re-started bike several times and now charging via USB. Still dead, any suggestions?
    Dress for fall & avoid it AlanColes's Avatar
    Aug 2013
    Bedford, Nova Scotia
    Try testing the battery to make sure it is actually charging/charged. I've not run across this problem, but I would want to first make sure there is juice to the unit.
    Regards, Alan - President BMWONS - MOA Charter Club #097, BMWMOA/BMWRA/BMWONS/Airheads
    Current: '14 R1200RT / '06 Ducati ST3s / '91 R100GS / '86 R80RT / '75 R90S / '73 850 & '70 750 Commando Prev: '04 R1150RT / '81 Honda GL1100 / '77 Suzuki GS750 / '73 Norton 850 Commando
    Nov 2017
    Belmont, NC
    I took the battery out and put it back in and now the unit seems to be working fine. Strange, it was turning on and off with the bike all day, when I came to stopping point the NAV powered down with the ignition normally but then did not come back on when I restarted the bike a few minutes later. Has anyone else had this experience?
    Aug 2013
    See if you can have the battery checked for its state of health. If it is okay, then I would look at connections. The Nav-IV is old enough now that there could be a bit of corrosion (often not visible to the naked eye) of the terminals. These can be cleaned with alcohol or a small pencil eraser (don't leave any residue at all). If that doesn't fix it then it may be a failing internal connection, or just a random "I'm gonna make you worried" glitch if you're lucky.
    Hope it works out okay. They're great pieces of gear but terribly expensive to fix or replace. Garmin does have repair centres if you need/want to go that route.
    Sep 2007
    So. Calif.
    Quote Originally Posted by redling View Post
    Not an unusual problem, but often solved by removing the GPS from its cradle and carefully cleaning the contacts.
    '17 R1200GS
    Priors: '16 R1200R, '14 R1200GS, '13 K1600GT, '08 R1200RT, '04 R1150RT, '05 R1200GS, '73 R75/5 (LWB).
  1. 86 R80 RT Dead
    By Zimm in forum Airheads
    Last Post: 11-06-2013, 01:23 AM
  2. Dead GPS
    By ind1mrg in forum Gear
    Last Post: 08-25-2012, 04:13 PM
  3. Dead at the age of 22
    By redclfco in forum Campfire
    Last Post: 09-29-2009, 03:37 AM
  4. 07 1200rt Dead Dead Dead
    By screamineagle in forum Oilheads
    Last Post: 02-10-2007, 12:47 AM
  5. HELP! - Dead R1100GS in VA
    By 104857 in forum Oilheads
    Last Post: 04-12-2004, 03:22 PM
