Results 1 to 10 of 10
Thread: No starter ?
    NOTGIL-T
    Jul 2008
    Level Cross, NC (So. of Greensboro)
    No starter ?
    2011 RT Just pulled off the cover to wash the bike for the first ride since October. Has been on a tender since new battery in September, everything works, plenty of juice, hit the Starter button and nothing.
    It has 10,750 miles and has never given any trouble, am I just, not thinking, is my age showing???
    Quote Originally Posted by DENNYMELCHER View Post
    What voltage is battery after sitting for 15 minutes with no tender?
    Does display turn on? Any clicks?
    Did you try in neutral? The clutch safety switch is known to go bad, but it will still start in neutral (also starts in neutral with bad side stand switch, but dies going in gear).
    Mansfield,MA
    Or- removing the cover tripped the kill switch
    Mod Squad
    2009 F800GS 1994 TW200
    NOTGIL-T
    Jul 2008
    Dennymelcher
    Quote Originally Posted by cide1 View Post
    Everything works, gauges, lights, horn, signals, radio. Not a sound, when I hit the starter switch.
    12.6v after 3-4 minutes, with everything ON. Iím really puzzled, as well as the other
    NOTGIL-T
    Jul 2008
    Dennymelcher
    Is there another Kill Switch other than the UP position on the Starter rocker switch??
    Did you try in neutral? 12.6 indicates battery is in a pretty good state, so Iím thinking a safety switch is acting up, either clutch, side stand or kill switch on grip.
    Sent from my iPad using Tapatalk Pro
    NOTGIL-T
    Jul 2008
    Dennymelcher
    I think itís time to hit the Owners Manual. Already too dark to wash the bike for in the morning, even if I did get it started.
    NOTGIL-T
    Jul 2008
    Dennymelcher
    Is there any way that I can check any of these switches myself?
    Do you have access to a GS-911? That will show the "State" of the switch (open/closed) that the ECU sees.
    davemason
    I had the same issue this spring with my 2012 RT. Parked the bike for the winter last year, all was fine. Tried to start it this spring, nothing. Could hear fuel pump, and all indicators were good. Turned out it was my starter switch. Dealer replaced all bar switches under a recall which I wasn't even aware of, and all is fine again.
  1. R75/5 Starter
    By codeman in forum Airheads
    Last Post: 05-14-2010, 11:18 AM
  2. Need help with starter
    By leadfoot in forum Hexheads/Camheads
    Last Post: 07-16-2009, 09:09 PM
  3. starter tip
    By ISAMEMON in forum Airheads
    Last Post: 06-01-2007, 03:45 PM
  4. K75 starter
    By cayuse60 in forum Flying Brick K-bikes
    Last Post: 04-29-2007, 11:23 PM
  5. Gap Around Starter?
    By RTNewbie in forum Oilheads
    Last Post: 03-25-2007, 04:19 PM
