Remove the nuts by the rubber cushions at the rear of the battery box. This will allow the battery box and battery to lean backwards and slide out. Tight fit but it should come out.
The subframe is on the inside of the main frame on my /7.
Another option is to remove the clam shell air box, filter, and air horns to the carbs. Then move the battery forward and out.
Ok got it out, did have to get a piece of wood and wedge it to spring the frame slightly and holding my mouth just right got it out.
Simple by Design
Could a person remove the air filter box and slip it out forward?
You could do so. You can also do heart surgery through your butt hole......but why?
Friedle
Friedle
Well, my first repair manual for the bikes with the aluminum clamshell air box instructed that was the way to do it.
Probably the real trick is to get the carbs set up in the proper upright position on reassembly.
I wouldn't think so. From time to time, I've unhooked the carbs and used rope or bungee cords to pull the carbs forward and out of the way while I worked somewhere else. Easy enough to slide them back into position. Bob's Your Uncle!
Actually, Bob was my Dad.
Bob's Your Uncle!
