Make sure you placed the fob battery correct side up.
Try starting the bike with the plastic key, or by placing the fob under the front seat.
Page 50 and 51 of your riders manual will show where to place the plastic key or fob.
I think I only see that light when the fob is out of range when I press the start button.
I purchased the bike as used...I do not have a plastic key. Where is “under front seat”...specifically ?
Though, w/o the plastic key this step won't do you any good. You may have to call BMW unfortunately
Tender states 100% and 14.4V -replaced fob battery...bike is comatose and won’t turn over and the cluster displays a single red icon. Any thoughts what may be wrong?
Did you see a low fob battery symbol on the dash before you replaced the battery?
I’d make sure FOB battery is a quality one, Panasonic or Duracell, I tied replacing mine with a generic battery, found it was dead!
Second step is move the bike as others have said, RF signals can inter fear with the keyless system
I found this out at a Mobile station that had fast pass at the pump
If all else fails it should still be covered by warranty
Any updates?
Could it be caused by a second fob from another bike? Doesn’t seem likely.
DAMHIK.... Did you take the protective clear plastic sticker off the new FOB battery when you put it in?[/QUOTE
Ain't technology wonderful. I love fuel injection and computerized engine management systems, but a computer to tell me how to control my tail light seems a bit much.
As soon as BMW figures out how to make a side
stand work, I might care about more that they concoct. Until then. Not so much ... Tech is good when it is good. And it sucks badly when they screw it up, as they sometimes do.
My 2016 RS is having similar issues. Push power button get red light. This is in my garage. New batty in bike and fob. If I push the power button repeatedly it eventually goes into start up check and all is well. Worried about getting stranded.
What was the outcome, resolution on your bike.
