Results 1 to 5 of 5
Thread: Touratech suspension
    Registered User crna59's Avatar
    Apr 2017
    Issaquah, WA
    Have a '17 f700GSLC and took it in for it's yearly service. Asked them what they would recommend for suspension upgrades. I told them I was looking at Ohlins and Touratech. One of the main reasons was every time I used the front brake, I was looking at the sky in the mirrors. Every bump, small or large, was jarring and I felt the bike was perfect except for this.
    Dealer recommended the Touratech Progressive fork springs and heavier oil. WHY THE HELL DID I WAIT THIS LONG???
    This is a total transformation! I though it would be a little better. Didn't know if would be like night/day! Bumps are almost non-existent. Expansion joints, small pot holes, broken pavement... nothing will phase it.
    This is the FIRST farkle you should buy. Forget handguards, skid plate, crash bars, blah... blah... blah... Touratech Progressive springs are the real deal. Have already scheduled an appointment to change out the rear shock.
    Bruce A. Brown #212072
    MSF 2-wheel Instructor
    H-D Riding Academy Instructor
    S/TEP 3-wheel Instructor
    Jun 2009
    Rochester, MN
    Nice!!!
    When you get your rear shock upgrade, go the extra step by properly setting your sag.
    http://blog.touratech-usa.com/2013/08/06/how-to-setting-suspension-sag/
    In a seminar at a rally a while ago, the speaker mentioned that suspension isn't to keep your fillings from rattling out of our teeth, it's to keep the wheels firmly planted on the road. Not a big deal when you're riding straight, but imagine leaned over in a corner going over a road imperfection and loosing traction, even for a split second.
    1995 BMW K75s - 100k and climbing!
    2007 BMW R1200RT - 62k
    2009 BMW G650GS - 22k and ready for Alaska!
    Registered User jamesdavidhoward's Avatar
    Feb 2010
    Aloha, NW Oregon, Portland suburb
    F-series suspension
    On my F650GS Twin (akin to today's F700), I've done:
    • Fork Valve Enhancement
      I used Ricor's weirdly-named "Intiminator" insert, which provides 2-stage valving and different valve rates for compression and rebound. It works very well. It is designed to work with a very low weight shock oil (5W), so the simplistic stock damper is left in place (and does almost nothing any more, and the Intiminator takes over). This means you haven't damaged or altered the OEM equipment. The Intiminator valving is designed for this low weight oil and does its control job almost by itself.
    • Progressive fork springs
      I used HyperPro progressive springs in the forks (about the same thing as you can get from TouraTech) - the variant which leaves the suspension height unchanged. A big improvement: a bit "softer" in riding around town, no bottoming when off-road.
    • Touratech rear shock
      When my OEM shock wore out, I found the Touratech to be cheaper than a stock replacement, with better features and very good feel and adjustability - riding by myself or 2-up with wifey.
    All of these were incremental improvements, each a noted improvement from the last.
    I can certainly 2nd the comment about carefully setting your suspension sag after the change-over.
    James D. "Jim" Howard jhoward@alumni.caltech.edu
    Anyone have a link to a tutorial on changing the fork and rear springs. I've purchased the touratech / hyper pro progressive spring kit but having trouble finding more details
    Feb 2010
    Fork Renew / Rebuild Instructions
    I have a Haynes service manual for the F800/650 GS Twins, and it has a thorough discussion of the fork disassembly and re-assembly instructions. Good photos for guidance, and specs like fork oil fill level, etc.
    Note, though: These forks rely on the pressure of the air trapped (by design) in the top of the fork - acting like an air spring added to the spring in the fork tube. Many folks will play around a bit with the oil fill height in the fork - just a little bit. It makes a noticeable difference.
  1. Replies: 7
    Last Post: 05-11-2014, 07:14 PM
  2. Touratech iBracket
    By rapz in forum Gear
    Last Post: 02-27-2013, 10:27 PM
  3. Centech AP-1 vs. Touratech TPS-15
    By grw in forum Oilheads
    Last Post: 04-16-2007, 08:20 PM
  4. Need Touratech help,pls
    By brownie in forum Gear
    Last Post: 04-24-2006, 02:51 PM
  5. GS with Touratech at the Rally
    By Daniel Cohen in forum Rally Forum
    Last Post: 06-28-2003, 06:54 PM
