The K was running when parked 5 years ago in a dry garage. not set up for long term storage. installed a new fuel pump kit w/hoses & screens. pump doesn't seem to be getting power, will not prime lines. normally you can hear the pump building pressure when you 1st turn the key on. that is why I replaced the pump to begin with. the bike will run/sputter if you spray some starting fluid in the air filter. where else can I look for an electrical problem on the fuel pump. fuse is good (not blowing fuses) thanks
