Have been in the brick camp for 16 years and over 100,000 miles. It is too big, too heavy, too tall and I am too old. Traded for a 1975 R-75/6 that has not run for 20 maybe 25 or it could be 30 years. I have drained and cleaned all that is proper to get it ready to start. Put in a fresh battery and turned the key. No dash lights, no telltale lights no speedo or tac lights. I went to the ignition switch and it had power. I then attempted to start it and it fired right up. I only let it run a few seconds because it didn't have an oil pressure light. I have since determined to all the other lights work. Only the lights in the the instrument pod don't work.
Question 1 Has this happened to any of you and is there any remedy that is simple. Question 2 Is there a wiring diagram that is better then the owners manual or the factory manual than can be read without a magnifying glass. Thanks for any advice
