On our K1300S bikes, I tipped back the final drive and also pulled back the front boot so I could check the splines. They were fine, but I still cleaned them and applied new lube.
I plan to do the same on our wetheads because I have seen some nasty rusty splines on new GSs and at least one said he had never went through a water crossing.
As mentioned above it's not mentioned in the service schedule.
On my 2005 RT I had to tip the final drive down to drain the oil, so it only made sense to grease the splines while they were accessible. It is easy and quick to do.
The issue is the splines on the transmission output shaft. You could not access those by simply lowering the FD.
I’ve tried that and, while possible, found it more effort than removing the swing arm. Doing so also allows for a careful check of the u-joints.
