Results 1 to 6 of 6
Thread: '98 1100RT Throttle synch adj question... or a few?
    Mar 2016
    Los Angeles
    Hi again,
    I'm trying to synch my throttle bodies for the first time. I have given up for the evening and will resume in the morning.
    I have made a manometer as per the internet (!). It seems to work, as I can get the initial idle set just fine. I am having trouble with sync under load, however. One question I have is: On the 98 RT, do I loosen and adjust only the right-side throttle cable, or both? (The 98 has a "Y" cable with one going to each throttle body, correct? Not a crossover?) Another question: I neglected to adjust the throttle freeplay screw at the grip (should be at 1mm for sync; was at about 4mm)... will that have made a difference?
    Thanks in advance from this relative DIY noob who's game to try!
    N
    Feb 2005
    Trinity, NC
    Correct. You have a bowden box with two cables exiting, one to each TB. This is an easier setup to work on than the earlier crossover.
    You must have "some freeplay" on both throttle bodies. If you don't have freeplay it is impossible to get idle and off-idle sync done. Just to be clear - you set your idle by adjusting the air bypass screws on the two throttle bodies (the "Big Brass Screws"). Turning the BBS clockwise will reduce air and should lower the idle. Counter-clockwise should increase air and raise the idle. Make sure you remove each screw and clean the tip, which is often coated with black residue. You also could remove the hose or cap from the metering hole at the bottom of the TB and spray TB Cleaner into the BBS opening - some of it will drip out of that hole.
    Off-idle sync is set using the throttle cables. Just make sure that if you tighten either of the cables, don't eliminate all of the freeplay.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Mar 2016
    Los Angeles
    Great thanks! So, do I make adjustments on both sides, or just the right? And do I set free play only at handlebars or at TBs, too? Hard to find definitive answers online.
    Thanks again!
    N
    Gerard jagarra's Avatar
    Aug 2016
    Reno, NV
    1994 R1100RS-(5/93)-,1974 R90/6 built 9/73,--1964 Triumph T100--1986 Honda XL600R
    Mar 2016
    Los Angeles
    Quote Originally Posted by jagarra View Post
    Thanks!
    Mar 2016
    Los Angeles
    Success!
    Valves adjusted and TBs synched. Running like a dream. Thanks for the counsel, folks!
  1. 2009 R1200RT Throttle Body Synch
    By Ridefar in forum Hexheads/Camheads
    Last Post: 05-12-2015, 04:07 PM
  2. Need Help with the Throttle Synch Cables 2012 R1200RT
    By wvpc in forum Hexheads/Camheads
    Last Post: 04-15-2015, 05:17 AM
  3. Throttle body synch on 2009 r1200r
    By gta in forum Hexheads/Camheads
    Last Post: 06-30-2012, 01:47 AM
  4. 1100rt oil question
    By RICH7196 in forum Oilheads
    Last Post: 11-04-2009, 04:04 AM
  5. Throttle Synch hiccup?
    By Bdiver in forum Oilheads
    Last Post: 10-18-2007, 01:56 PM
