Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
Thread: Stop and Go tire plugger
    P Monk
    May 2005
    Orange, Texas
    On the way home from a week in the Texas hill country, thought the road noise was a little loud. Looked at the tire pressures and found the rear to be 29lb. No yellow warning light so started looking for parking place. Good old Dollar General looked good, then got flashing red warning and sure enough the rear was going down. Finally a reason to use the Stop and Go I bought at Billings. Problem is I never even looked at it before I needed it.
    Was not as easy as the pictures. In fact it was mighty difficult. Made three attempts before I got the plug into the tire, and then it still leaked. Fortunately DG had a rope tire repair kit for less than $4 and it did the trick and I ran home a couple of hundred miles with no air loss.
    I am not knocking the Stop and Go. After watching several youtube videos, I can see where I wasn't doing it exactly right. Did not have a feel for just when the plug was pushed into the tire using the allen wrench supplied. Takes a lot of pressure to squeeze that big plug through a tiny tube!
    So lessons learned. Try out your stuff before you need it. Practice on an old tire, see what the plug looks like from the inside. Feel how much pressure it takes to insert the plug. That is what I am going to do when my new tire arrives. Finally, the old sticky rope plug will still work in a pinch.
    P. Monk
    74 R90/6 (the Black Hole), 2011 R1200RT.
    Registered User 6322's Avatar
    Mar 2012
    Riggins, ID
    Really good advice. Traveling far and wide on BMWs since the early seventies. I've always asked myself the question: what could leave me on the side of the road that I can prepare for? Simple stuff like light bulbs at night or fuses and a flat anytime or anywhere. I've always traveled with the tools and parts to fix any of the above and get back on the road. For my tube type bikes I've always got a new tube for the rear tire (the most likely one to go flat), tire irons and a compressor. I've fixed several tires on the side of the road over the years including one in front of a highway patrol who couldn't believe I had everything I needed. I was back on the road in fifteen minutes. He was ready to call a wrecker for me. With my tubless bikes I carry the stop n go as you do and it has saved my bacon though it does take some practice. Believe it or not, there are some places, like where I live, that don't have cell service. You are on your own. No tire pressure monitors on my bikes. I just sense something in the handling like a slight wiggle in the back end that shouldn't be there. Get stopped post haste and often find a back tire going down. Check tire pressures each morning before beginning the ride and make sure all bulbs are lighting up. With the right stuff it's only a minor inconvenience. Safe travels down Texas way.
    Gary Phillips - #6322
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '93 K1100LT, '00 R1100RS
    Mansfield,MA
    I think that with tire plugging, most thinking is that I dont want to make the hole any larger!..... Not having the optimum size hole works against the plugging process- really. How the optimum size is known....practice- and who wants that.
    I know a fleet mechanic that just brings a drill with the optimum size bit and makes the hole. A quick and 1 try plugging and the vehicle is off again.
    As long as you have plugs, breaking or otherwise wasting a couple, I find par for the course. After a couple of tries, the third try is usually the charm.
    Mod Squad
    2009 F800GS 1994 TW200
    Aug 2013
    Bedford, Nova Scotia
    Quote Originally Posted by dpmonk View Post
    ... Was not as easy as the pictures. In fact it was mighty difficult. Made three attempts before I got the plug into the tire, and then it still leaked. Fortunately DG had a rope tire repair kit for less than $4 and it did the trick and I ran home a couple of hundred miles with no air loss.
    I am not knocking the Stop and Go. After watching several youtube videos, I can see where I wasn't doing it exactly right. Did not have a feel for just when the plug was pushed into the tire using the allen wrench supplied. Takes a lot of pressure to squeeze that big plug through a tiny tube! ...
    Glad you were able to get things working. It can be frustrating being prepared for a problem and then having to struggle even though you'd come prepared.
    I've plugged tires before but not needed to since I got my Stop&Go, so don't have any experience with it specifically, just with others.
    Have you watched the Stop&Go video that they provide for you to load on your phone and have available as a refresher? https://www.stopngo.com/pocket-tire-...ubeless-tires/
    If so, could you comment on:
    • Do you feel there needs to be anything adjusted in the video or was it just the written instructions that gave you the problem?
    • Are there links to other videos that you feel are better from the experience you had?
    Thanks for sharing.
    Regards, Alan - President BMWONS - BMWMOA/BMWRA/BMWONS/Airheads
    Current: 2019 R1250RT / '06 Ducati ST3s / '91 R100GS / '86 R80RT / '75 R90S / '73 850 & '70 750 Commando Prev: '14 R1200RT / '04 R1150RT / '81 Honda GL1100 / '77 Suzuki GS750 / '73 Norton 850 Commando
    P Monk
    May 2005
    Orange, Texas
    tire plugging
    Here is one, but I did not get a kit with the handy plug gun.https://www.youtube.com/watch?v=pKCsh6jST_U
    Think my first mistake was not cleaning out the hole enough to easily insert the tool. Secondly, I did not pull the plug out to set the mushroom head to the tire. Finally, I think if I had aired up the tire before cutting the plug, I may have been able to seat the mushroom head by pulling on it.
    I underestimated how tight to screw in the plunger with the allen wrench the first few times I tried it so the Plug never fully entered the tire.
    P. Monk
    Are we there yet? tonyfr's Avatar
    Apr 2007
    SAT - LAX
    You need the Stop & Go with the gun kit. I have used mine twice on my 12RT and twice on two cars. I ran about 8,000 miles on a plug in the rear tire on my RT.
    2009 K1300 GT
    1984 Kawasaki ZX750-E1 Turbo
    1990 Kawasaki ZX600R
    2005 R1200 RT - gone
    I have a Stop&Go kit. It is critical to do it right. I stuck the plugs in the screw-on tip and it failed to work. So I regrouped the troops and did it right. Follow directions and it works well. I had a tire I absolutely could not get a gummy worm in. I used the Stop&Go and it was fine.
    Registered User WalterK75's Avatar
    Feb 2009
    Mississauga, Ontario
    I fixed a rear tire with Stop&Go. The hardest part is cranking the plug in properly. It bottoms out at one point and then it requires some real force to continue past the fake bottom to the end. It took me three tries to get this right. Thankfully I was at home in my garage. I stretched the end, cut it off and inflated the tire. I rode for several months on the plug and had no air leak at all.
    Walter
    "Every decent man is ashamed of the government he lives under."
    H. L. Mencken
    Registered User marcopolo's Avatar
    Feb 2005
    Alexandria Virginia/Ottawa, Canada
    Tried my Stop 'N Go last year on the road, with the help of two riding buddies. It did not work, so we tried my friend's good old rope-style kit. Worked like a charm. I ditched the Stop 'n Go, and now carry a rope kit.
    Mark
    2015 R 1200 GS Adventure
    AZ
    The Stop-n-Go works, and works well, if, you use it properly, and if, you get the "extruder" gun kit. The gun pump really makes it easy. I carry the instructions in the bag with mine and actually read them...
    MOA #107139
    RA #28511
    Nov 2005
    Calgary, Alberta
    I took the Anderwerks tire plugging course with the Stop 'n Go last year. Now if I can only remember how to use it if I need it....
    Rinty
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    Video from Stop n Go.
    Anyone use this method successfully? That gun would seem to take up valuable space...
    My fleet: 2015 R1200GS, 2017 Toyota Prius Prime (plug-in hybrid)
    P Monk
    May 2005
    Orange, Texas
    they make it look so easy
    I guarantee you the effort to push the plug through the nozzle requires more effort than shown in the video. It took one person with a pair of pliers holding the tool and the other cranking on the allen wrench to get it to go in.
    P. Monk
    Feb 2009
    I agree the video doesn't give the right impression of the amount of torque needed to get the plug set. However, I was able to do it by hand without too much difficulty.
    Walter
    H. L. Mencken
    Just another rider 61242's Avatar
    Wisconsin
    Quote Originally Posted by AKsuited View Post
    I used one of these kits a couple days ago to plug a R12RT rear tire. Disclaimer: I was doing this in my garage and not on the roadside. I also used a bit of rubber cement to help the probe/nozzle slide into the hole. I also had access to my compressor and didn't use the CO2 inflators.
    My $0.02 is the kit works as advertised.
  1. Tire Plugger gets a D-
    By redclfco in forum Gear
    Last Post: 03-17-2011, 04:14 PM
  2. Missing Part Stop and Go Tire Plugger
    By MICHIGANMIKE in forum Gear
    Last Post: 08-08-2008, 02:20 AM
  3. Stop-N-Go Tire Plugger
    By swall in forum Oilheads
    Last Post: 12-28-2007, 03:22 PM
