Don’t
They are now made in China, pure junk
Sorry
Jim
Actually the box says Thailand - don't know if that's any better.
Ski
Ski
Look at Malhe OC306 filters, OEm for Bmw, chart says not for WETHEAD bikes, but my 15 came from factory with this size filter, my selling dealer has no issue using this filter, just about 1/4 inch shorter than new style all other specs are the same
Jim
I've used the K&N on my RS wet head. Easy on , easy off. Engine has not blown up! 28k miles.
Not sure the made in China fear is completely warranted. iPhones are made there, BMWs are made there, Volvo is now chinese brand, VWs are made there. Both Boeing and Airbus make parts there.
Up until the early 50's lots of engines ran without oil filters using oil and manufacturing tolerances that were greatly inferior to those of today. Lots of small engines still run without filters. BMW motorcycles until 1969 ran without them.
Indeed they did. And routine maintenance included taking almost the entire engine apart to clean the slingers. That fails to convince me that filters and filter quality don't count. I confess to being an outlier maybe, because Voni and I tend to keep bikes for a long time. My first K75 died in a crash at 369,000 miles. Voni's R1100RS is out front at 412,000 miles (the engine was replaced at about 390K making ugly bottom end sounds). My R1150R is in the garage with 190,000 miles. So oil and filters count to me. I, by the way, have always used simple petroleum SG rated motorcycle oil in the correct viscosity - Castro dino 4T to be precise, once GTX lost its SH rating.
Paul, you are definitely an outlier on mileage and retaining bikes. You can read discussions of people trading 2017 GS's because an electronic dash came out. BMW's 3asy Ride plays into the constant exchange of motorcycles. Half of my fleet is over 25 years old as well, but unfortunately I have not covered the miles that you and Voni have. You have several strong data points for "good" filters and "common" oil. Missing is anyone who attests to have run engines into the ground at significantly lower mileage from having run inferior filters. The chance remains that you might have achieved a similar result with $2 SuperTech filters from WalMart. Nobody knows. Certainly you have reason for great confidence in the regimen that you have chosen. But that is different from disproving the null hypothesis.
My suggestion is very simple. Cut a BMW filter apart and cut a K&N filter apart. Observe the construction. Observe how fine or course the filter media is. Observe how many pleats there are in the filter media. Then reach a conclusion. Or go find one of the many articles documenting how this was done. Then reach a conclusion. I agree that China can produce some good products, and I also agree that it can produce monumental crap. But do your own research. I have read several such test articles. I know what I think but my telling you won't do any good. You will need to actually do critical thinking for yourself.
Have you done this with the BMW and the K&N? Just thinking critically.
