Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 50
Thread: 83 r100
  1. #16
    cafe racer
    Great stuff just picked up a 83 R100 stripped it and order all the parts motogadet from Dime City nice people, yours looks truly incredible !
    has anyone seen a custom gas gauge ever fitted ?
  2. #17
    Pismo Beach, CA
    Just run it until you have to go to Reserve; there is about 15 miles worth of fuel on either side. My "custom gas gauge" in the odometer. One less thing to fail.
    It doesn't appear that this critter will be a long-legged touring bike.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
  3. #18
    Apr 2018
    NorCal
    Haha yeah Dime City is a great place to pick some stuff up.
    Ill post some more custom things I did later...
    Still deliberating on the gauge setup.
    Been busy checking little things off my punch list lately.
    Stay tuned...
  4. #19
    Apr 2018
    NorCal
    bike by keips66, on Flickr
    Getting dialed in.
  5. #20
    Apr 2018
    NorCal
    Pulled the trigger on the Motogadget ChronoClassic with the dark edition LCD.
    Cant wait to get it installed. Question is, I think the current stock idiot lights are Oil, Charging, Turn and Neutral. The sun has obliterated the text under the lights.
    I'd like the gauge to read the oil pressure, along with some other cool functions. Im guessing I need a new sensor for this? The stock one is simply for the idiot light correct? I feel idiotic asking that for some reason.
    Also, is there a plug of some sort that fits into the old speedo gear hole? Its obsolete since there is a magnet that goes on the rim.
    Untitled by keips66, on Flickr
    Took it down to Half Moon Bay to check out Dream Machines...
    Couple recent things: Braided fuel lines, custom steering stabilizer knob (mine still works well) but snapped off the old plastic knob when removing the tank.
  6. #21
    Pismo Beach, CA
    Coming together nicely! Is that 2" header wrap?
    Probably something at the hardware store. You might look through the McMaster-Carr catalog for hole plugs > https://www.mcmaster.com/#hole-plugs/=1cncsnz
    Keep in mind that the bolt that secures the speedo cable has a hole through the center to vent the transmission. Don't plug it up.
    Lew Morris
    1963 Dnepr
  7. #22
    Apr 2018
    NorCal
    ^ Its 1.5 Titanium black wrap.
    Got the gauge. Could not be happier. It is a very nice piece. Here's what it looks like on the bike. Temporary toggle switch, until I get a better button.
    IMG_9850 by keips66, on Flickr
    IMG_9857 by keips66, on Flickr
    IMG_9861 by keips66, on Flickr
    IMG_9862 by keips66, on Flickr
  8. #23
    Apr 2018
    NorCal
    Broke down today...
    Its good to know my new gauge charging indicator light works. I thought I could limp it home, but it sputtered and died. The gauge voltmeter displayed 9.1V whenI pulled it off the freeway. Tried to start it, but it didn't have enough juice to crank.
    Its comforting to know that 5 bikes stopped to offer assistance and a few more were about to while waiting for the tow truck. I will definitely return the favor.
    Got it on the hook, and took it home.
    The charging system is one thing I did not touch yet, and now I need to figure out if the diodes, voltage regular or rotor are shot.
    Is there an upgraded charging kit? (earomotor electrics?) or is stock good, and mines is just worn out?
  9. #24
    Aug 2003
    Marion,Ar.
    Yep, it's all available. Updated ignition, charging systems. May be time to give Rick Jones a call .
  10. #25
    Liaison 20774's Avatar
    Maybe it's just the battery? 9 out of 10 times, that's the issue. Have it load tested. While you've had it, have you measured the voltage at the battery terminals with the engine running at around 3K RPM...should be well above 13.5v.
  11. #26
    Apr 2018
    NorCal
    Haven't had it load tested, its rather new, but small. I did check running voltage when I got the bike and I think I remember it was in the 13's. I charged it overnight, and will fire it up and check to verify. Then, start chasing down the other possible culprits. Who is Rick Jones?
  12. #27
    Rick Jones...friend of Airheads and the Air Marshall for Alabama. He owns www.motoelekt.com/.
  13. #28
    Apr 2018
    NorCal
    Ahhh, intriguing. How does his stuff compare to EME stuff? Im not sure I need 600watts, but I did want to upgrade the stock system.
  14. #29
    Registered User tanker4me's Avatar
    Mar 2011
    LoCal
    Verify all grounds before spending $.
    The battery & diode board ground straps were replaced on my 76 R90 a couple years ago, it’s the original charging system otherwise.
    Bill
    We are all here for a spell, get all the good laughs you can.
    Will Rogers
  15. #30
    Pismo Beach, CA
    Mine just went Tango Uniform. It's almost five years old; a pretty good run nowadays. It was always on a Schumacher battery tender when garaged.
    Speaking of Rick Jones ... he's been in absentia. He didn't return two of my calls, has anyone actually spoken with him lately?
    Lew Morris
    1963 Dnepr
  1. CS or R100?
    By JOHNP in forum Airheads
    Last Post: 05-25-2013, 01:53 PM
  2. !983 R100 to SC,
    By 140008 in forum Sidecars and Trikes
    Last Post: 07-17-2012, 12:25 PM
  3. R100/7 Buy it?
    By not2brite in forum Airheads
    Last Post: 08-10-2009, 01:00 PM
  4. R80 or R100 ?
    By Kirbster919 in forum Airheads
    Last Post: 04-13-2009, 07:52 PM
