alancoles
Dress for fall & avoid it
Glad the bike is back and running. As has been said, diesel in a gasoline engine typically just requires cleaning, gasoline in a diesel (and running it) can mean a total rebuild!!!
I'd buy a can of either Techron or Seafoam, your choice, they're both very good at cleaning injectors, fuel systems, etc. Then take your additive and go to the gas station, but before filling the tank with gas 91-AKI (or 93 if you like), put the prescribed amount of Techron or Seafoam into your tank, then fill it with gas, right to the top. That may help your fuel gauge and putting it in before you fuel up will mix the additive extremely well. Then take it for a good long run at highway or good secondary road speeds. Use your trip-meter for fuel range and stop to refill when you think you're at half-full. See how much it takes and that will give you an idea of your range, which may be reduced until everything is back running smoothly.
As was suggested, the fuel gauge may just need 1-2 tanks of fuel to loosen it up and both Techron and Seafoam can help with that. But it is important to fill the tank to the top each time to get the gas as high up on the gauge as possible so that it can clean/dilute the diesel. I'd even take some Techron or Seafoam with me and when you do your half-empty fill put in enough for the half-tank fill, so you are continuing to clean everything. If the gauge doesn't start working properly after 2 full tanks then it may require removal for a complete cleaning.
