10drum
I changed everything in the carburetors except the floats and pins. I put about 1 1/2 gals in the tank, I got everything dialed in, the bike runs great. I filled the tank, then the right carb started leaking, after it sits for a few minutes. Then, I installed new floats and pins in both carbs. The right carb will still leak if both petcocks are open, or if the bike is on it’s kick stand. The bike is still running good. Closing the petcocks after a ride is common nature for me......most of the time. I’m suspect of the float valve seat???
