My 2017 runs about 83°C pretty constantly, however she'll pop up to 99°C and then the fan kicks in.Hi,
I understand it may change with outside conditions, but what is average running temperature for a 2016 1200 GSA?
Seems that mine get to 202/ 205 very easily while riding. If it is too high what to look for?
Thanks for any input.
Louis
With My Motorcycle up on the Nav 6 on a 17 GS I see 180, 182.4 mostly.
Having said that, 200-205 is quite normal for a car engine, especially newer and smaller displacement ones. This is a more efficient temperature for an engine to operate in...
I ride a 2014 RTW so unfortunately, I can't get a numerical readout of my coolant temperature, just have the scale next to the fuel level scale.
From those that have responded, it would appear that low-mid 180's F is the norm.
A couple of questions:
- have you checked your coolant level? Low levels will result in higher than normal operating temperatures
- does your fan come on very often? If no,
- has your fan ever come on?
My 2014 1200gsa runs at 83 'C at regular speeds. In very slow speeds, it'll go to 100 'C at which time, the fan kicks on.
These are my readings with aftermarket ALT RIDER rad guards installed. Please note that these guards and rad should be kept clean.
Its not a bad thing to wonder and want to know.The GSA is the only bike I have with water cooling so maybe I worry too much.
