RPGR90s
Member
Would anyone happen to know the ring end gap and land clearance specs for the Motoren Israel forged pistons? These kits come with the forged pistons, rings, pins and circlips.
I had a shop install these (bored 1st over) in a R90 and I'm doing a pushrod seal replacement.
Since I never checked them myself and the bike uses a little bit of oil, I figured now is the time to check them out. Heads will be gone through as well.
https://www.motoren-israel.com/Shop...0/6-90S-in-90-5-mm-1-Uebermass-2-St::558.html
Thanks,
RPGR90s
Thanks,
RPGR90s
