jagarra
Gerard
I went on a ride today to test out my new lowered Wilber shocks on the R1100RS. Bike handled great, went into corners nice, felt more confident. Now the issue. I noticed while in 5th gear that the tach and speedo were in sync (same place on the dial in relation to each other) When I was on the freeway, gear lever said it was in 5th, play in lever, but tach was at 5K and speedo was at 70. Something is off, can the tach be lying or is it more serious??
Since I messed with the center stand I first thought that may be cause, but everything clears with no issue. When I down shift, it goes into every gear with a corresponding jump in RPM. Drop from 5th to 4th, pretty small in tach jump. Last time I rode before this, there was some hesitation in going into 5th and the proper tach drop.
My tranny is the M93.
