HowardR1200RT
Recently read an article on what the author called friction point shifting where you dont pull the clutch lever in all the way you just keep slight up pressure on the shift lever and then pull the clutch lever in until the tranny shifts and then let the clutch lever out. Actually works quite well for upshifts but would like other opinoins as to whether this is good, bad, or just another way to shift.
Hope this doesnt turn into an oil thread.
