Results 1 to 9 of 9
Thread: Valve Adjustment Interval - K1200S
    Left Coast Rider
    Nov 2011
    I know that the computer thingy will tell me when my bike needs to have its valves looked at but I was hoping one of the wizened denizens of maintenance wisdom could give me an idea on how frequently that might be for a bike ridden mainly on highways and not in the city.
    Thanks in advance!
    Sep 2006
    CENTEX USA
    well, I'll bite
    After doing around 8-10 checks on Wedge engines, I have not found a valve out of tolerance...one or two were headed in direction of maybe needing a shim on a K12GT, but subsequent check had it at same clearance a few years later.
    It is a job for the patient mind, as a lot of stuff has to come off and checking all those valves is another Zen experience. It's a two cup of coffee and a lunch break after you remove the valve cover for me.
    None of ours or the others I have checked were driven at Warp8 near engine redline at any frequency if ever as I know the pilots. I think it's a good thing to check because every engine is not the same, but as mentioned haven't seen an issue.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    There’s a computer for that?!?!?!?!
    Kevin
    Team Pterodactyl
    2018 Ural Gear Up, 2017 R1200GSA
    Sep 2006
    CENTEX USA
    They call it a countdown to valve check, but I haven't seen a dash code saying it was overdue. Only the service interval warning on bikes with the full onboard computer. Our S's were basic models with miles to go after reserve hit about only info other than general warnings.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Yep, it's not often I hear of a K1200/1300 needing a valve adjustment.
    Lee
    2016 R1200RS
    MOA # 30878
    Left Coast Rider
    Nov 2011
    Thanks guys. I appreciate the info, as always.
    Registered User CABNFVR's Avatar
    Laurel Park, NC
    We've had many K series bikes, four of which were K1200S/K1300S. I have the valves checked roughly every 25k but the wedge engines have never needed adjusting. I'll throw in a humorous disclaimer ..... Way back in time we were on an 8000 mile 3 1/2 week cross country trip, part of which was a stop for a BMW national rally. I asked Frank Stevens, BMW National Service Rep (I probably butchered his title, but you get the idea) if we needed to have the valves adjusted on our 1995 R1100RSL before we got home.
    His reply was classic, and I can still quote him, "No, but remember I sell valves."
    "Have BMW. Will Travel"
    Mehrten
    Nov 2004
    Arizona, USA
    Another Data Point
    Our 2008 K1200GT is getting close to 122,000 miles.
    At 40,548 the cam chain jumped two teeth - I could hear the valves hitting the pistons!
    The shop did a leak down test, all good; a valve check, all good; and replaced everything to do with the cam chain and tensioner.
    Some 80,000 miles later the valves are still where they were when the shop did the check back at 40,548 miles.
    These bikes seem to have very tough shims and cams.
    Though it is a bit of work to get to the valves, I do plan on checking then as called for by the OEM repair manual, every 18,000 miles.
    While all the body work and the radiator is off its a good time to clean everything up, especially the radiator out here in the desert southwest.
    Cleaning the radiator was far more valuable than checking the valves on my K1300. It has made a big difference in how quickly the fan kicks ON.
    Unfortunately it is almost the same amount of Labour to do valves or do both valves and clean radiator.
    Going forward I will be spraying water with simple green thru my radiator more frequently.
    Seek Fun. "Any fool can criticize, condemn and complain--and most fools do" BF
    2009 K1300GT,
    2011 R1200GSA
    2014 Kawasaki DTracker; 2016 Honda NC700 DCT
  1. 2008 R1200RT with 31000 miles Valve Adjustment Interval?
    By ExGMan in forum Hexheads/Camheads
    Last Post: 05-02-2013, 09:53 PM
  2. R1100 Alternator Poly V-belt adjustment interval?
    By mark from maine in forum Oilheads
    Last Post: 08-30-2010, 01:23 AM
  3. Valve adjustments interval
    By Tbarcia in forum Airheads
    Last Post: 02-18-2009, 01:30 PM
  4. Valve Shim Adjustment Interval
    By 37071 in forum Flying Brick K-bikes
    Last Post: 10-30-2008, 11:55 AM
  5. K1200S Valve Adjustment?
    By beinin in forum Flying Brick K-bikes
    Last Post: 09-18-2004, 02:29 AM
