Results 1 to 15 of 23
Thread: Gps connector in k1300s ?
    Sep 2017
    Hagfors, Wermland, Sweden
    Just bought a Gps for mounting on my K1300s. Is there a connector fitted on the bike wiring loom already to use the 3 pin rep connector that can be purchased from bmw ?
    If so where is it?
    My old f800st had this, k1300 must likely but i dont know where it is on the bike.
    Bmw K1300S 2009 , Lava orange metallic.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    There's a white plug in front of the battery. It may have a black protective cover on the plug. The black thing laying on top of my battery is the cover.
    The plug is circled in red.
    Lee
    2016 R1200RS
    MOA # 30878
    Mansfield,MA
    Nice wiring job Lee
    Mod Squad
    2009 F800GS 1994 TW200
    May 2003
    SW Iowa
    Nice wiring job Lee
    That's because the shop did it 😁
    Lee
    2016 R1200RS
    MOA # 30878
    Sep 2017
    Thank you Lee! Searched realoem and an order for the plug is made.
    Knight-Errant 1957mpd's Avatar
    Feb 2018
    Las Cruces,NM
    NAV VI for K1300S?
    Quote Originally Posted by mattias_k1300 View Post
    If so where is it?
    Is there a mount for the NAV VI that may be installed on a 2010 K1300S?
    May 2003
    SW Iowa
    Quote Originally Posted by 1957mpd View Post
    Welcome to the forum.
    Are you looking for a cradle to power the Nav, or a mount to attach the unit to the bike?
    Lee
    2016 R1200RS
    MOA # 30878
    Feb 2018
    Las Cruces,NM
    Mmm. I guess, both. I have not bought a NAV VI, yet, because I do not know what accessory mounts are available for the K1300S cockpit. I've seen a few photos of persons using Garmin Zumo's, but the images are never close-ups so I don't know how these were mounted. Thanks for asking.
    May 2003
    SW Iowa
    BMW has a cradle that fits the Navigator IV, V and VI.
    I think the Zumo 660/665 will also work, but you need to check on that.
    Lee
    2016 R1200RS
    MOA # 30878
    May 2003
    SW Iowa
    At first I used the top part of a Ram handle bar mount and attached it to the lower half of my clutch lever clamp.
    I had to file out the Ram part and use longer bolts to make it work.
    Later I found a used Verholen ball that screws in where the plastis BMW Roundel is.
    Ram sells a ball that screws into the same spot but has a unfinished look.
    Lee
    2016 R1200RS
    MOA # 30878
    May 2003
    SW Iowa
    One more option.
    http://pirateslair.net/BikePenR.htm
    The ball on the left is another option.
    It's made by Hornig
    Lee
    2016 R1200RS
    MOA # 30878
    Feb 2018
    Las Cruces,NM
    BikePenR GPS Mounts - Pirateslair.net
    I like the GT10 for K1300S from Pirateslair.net - BikePenR GSP Mounts. Gotta' give up the Roundel in the center of the bars (which may be heresy - will leave that to an Inquisition....) but it's elegant. Thanks Lee.
    May 2003
    SW Iowa
    [QUOTE=1957mpd;1120671]I like the GT10 for K1300S from Pirateslair.net - BikePenR GSP Mounts. Gotta' give up the Roundel in the center of the bars (which may be heresy - will leave that to an Inquisition....) but it's elegant. Thanks Lee.
    The BikePenR mounts I've seen are well made and Pirate is a good vendor to do business with.
    Lee
    2016 R1200RS
    MOA # 30878
    Got a Question
    I have the cradle for the Navigator V. It has two sets of wires with plugs. Where do they connect? It came with absolutely no instructions, but it did have a packet of Body & Bike shower gel.
    May 2003
    SW Iowa
    Quote Originally Posted by zoomie View Post
    Post # 2 shows the connector.
    You only use one of the cradle connectors on the K1300S.
    Lee
    2016 R1200RS
    MOA # 30878
  1. Replies: 11
    Last Post: 05-19-2017, 03:46 AM
  2. Trailering K1300s
    By sjmyott in forum Wedge K-bikes
    Last Post: 08-20-2016, 10:26 PM
  3. No updates for the K1300S?
    By sugarhillctd in forum Wedge K-bikes
    Last Post: 11-18-2015, 05:09 PM
  4. Replies: 3
    Last Post: 02-08-2013, 02:31 AM
