Have you checked the fluid level in the lift cylinder?
Friedle
I sense confusion.
Lift table manual is here: http://https://manuals.harborfreight.com/manuals/68000-68999/68892.pdf
Page 7 explains how to check and fill the hydraulic fluid. Hydraulic Jack fluid is available at most auto parts stores.
I fixed the link- ^^^^^^in your quote. ...
As the OP, let's break this down. A hydraulic cylinder that needs additional fluid would either not raise or would only raise partially. We've all seen this. A hydraulic cylinder that "slowly drops" is slowly bypassing fluid around the cylinder seals or possibly the pump seals/bypass valve that allows it to lower. The reason for the post was to find someone who has experienced this and spent the time researching the fix. I was hoping for these possible answers so I could benefit from their learning experience.
something like:
1) Only three seals which were easy to find at the local hardware store.
2) HF has a rebuild kit for $X.XX.
3) A replacement cylinder is only $12 so don't waste time rebuilding.
Google, here I come!
