Greetings MOA mates, I currently have a starter issue on my R75/5: When I click the starter switch, the starter will start cranking but will not stop until I pull the battery. I am still in troubleshooting phase and have done my usual web research (I am new at Airheads maintenance). A lot of advice has mentioned the modifying to the relay as per Snowbum's advice: http://bmwmotorcycletech.info/slash5cricket.htm.
I just purchased this bike not too long ago and both the starter relay and starter switch have been replaced. I have inspected these parts and both look to be OEM equipment. The relay is SR9570 (1-350775) as per specs, it even says manufactured in 2016, made in Germany! The wiring colour code appears to match everything I can find on the internet, so I am not sure yet what the problem might be.
My first question is, since it is so new, should I still crack it open and do the retrofitting? As soon as time permits, I will still go ahead to check all the testing on the relay, wiring and starter switch etc first but I am just wondering if Snowbum's recommendation is applicable to older relays only?
Thanks first.
Henry
Thanks first.
Henry
