Page 4 of 4 FirstFirst ... 2 3 4
Results 46 to 55 of 55
Thread: Spark plug change gone wrong :(
  1. #46
    Watch This!!! junkjohn's Avatar
    Feb 2010
    Cape Cod, MA
    Did he ever get the socket out?
    John Simonds
    2017 R 1200 GS Adventure
    1975 Norton Commando 850 Roadster Mk 3
    If it ain't broke, fix it 'till it is.
  2. #47
    Nov 2017
    Collierville, TN
    Quote Originally Posted by wyman.winn View Post
    pappy35...i know that...i have worked on both vintages of R1200s....i have both the 14mm and 5/8" thinwall 12" deep sockets...never had a problem with either...
    05-09 Hexhead plugs... https://www.ngk.com/product.aspx?zpid=26310 5/8" (16mm)
    10-13 Camhead plugs... https://www.ngk.com/product.aspx?zpid=26330 9/16" (14mm)
    I was responding to Mr Stache...
  3. #48
    Feb 2019
    Pueblo, Colorado
    may i ask, what bike are you talking about...?
    Sorry I should've listed that 09 RT.
    Sent from my Pixel XL using Tapatalk
  4. #49
    Aug 2018
    Bolingbrook, IL
    I vote for Heat / Cold. Use a canned air spray that gets darn cold from the Office Depo store. Spray it on the socket to shrink it. Heat gun expands things, so ok to then warm it and repeat with cold.
    More important, drink a beer in between each step.
    2003 K1200GT
  5. #50
    Feb 2010
    Cape Cod, MA
    It looks like the original poster has not posted since 11-12-17.
    John Simonds
  6. #51
    Feb 2019
    Pueblo, Colorado
    Seems that the OP got his socket stuck in the upper plug hole. I had no problem with regular Craftsman chrome socket on upper plugs. The left lower one gave me a scare, the socket fit fine and backed the plug off about 1 full turn, then stuck. I was able to wiggle it out with ViseGrips and a few choice words. That socket has been ground down, and now has good clearance. Live and learn.
  7. #52
    I've seen this happen a number of times when somebody goes after the spark plug while the engine is cooling down ... easy to get that socket stuck! Some good suggestions in the thread for getting it out. I hope he managed to fix it!
    Your MOA Digital Media Editor since 2015 | Lifetime Member #87301
    '05 R1200GS | '98 K1200RS + Hannigan Classic sidecar | '19 Indian FTR1200S
    Check out Chasing the Horizon, a podcast by, for & about motorcyclers
  8. #53
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    That is why the only thing you do on an engine when it is warm, is drain the oil. The rest of the work is done cold or ambient temp up to a point of course....YMMV
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, 17 R1200RT
  9. #54
    Feb 2019
    Pueblo, Colorado
    Quote Originally Posted by chiba View Post
    I did mine completely cold, the bike had been sitting for 4 to 5 hours. Weird that only the left side lower gave me a problem. Not now with the super clearanced
    poorboy special socket.
  10. #55
    Registered User time2ride's Avatar
    May 2017
    Oro-Medonte, Ontario Canada
    I made that mistake once as well, after a ride was going to change the oil and figured I should adjust the valve clearance as well. I tried for two days following all the tips from a couple of threads on how to do it. After a couple of days of trying I decided best to leave it to the pros and took it to a motorcycle mechanic I use who has a small shop and is great. He and his head mechanic worked on it off and on using cans or Wurth freezing spray and lots of fine language . Told them while they were in there they might as well do the valve clearance adjustment, oil change, and new spark plugs. All in including our exorbitant tax rate in Ontario (13%) and I was just slightly over $600 cdn. Best money I ever spent for the piece of mind that I wasn’t going to damage the engine case. Immediately went out and bought the same socket he uses. Learned my lesson - oil change when engine warm, everything else cold!
    2005 R1200RT
    Brian
  1. Spark plug change on 2010 r1200rt
    By chuckr in forum Hexheads/Camheads
    Last Post: 01-16-2019, 07:05 PM
  2. '93 K75s/ABS - Stumbling under acceleration after spark plug change.
    By lanceharrison in forum Flying Brick K-bikes
    Last Post: 02-13-2015, 04:10 AM
  3. Spark plug change
    Last Post: 06-13-2014, 11:13 PM
  4. Replies: 8
    Last Post: 07-25-2013, 03:15 PM
  5. Elf Pegs and Spark Plug Change
    By 115563 in forum Oilheads
    Last Post: 09-05-2007, 07:21 PM
