Results 1 to 15 of 20
Thread: My DIY Throttle Body Sync
    Jun 2017
    Sunny Southern California
    It's always fun to be a MacGyver, so I thought I would share pics of my latest project: a home-made manometer for DIY balancing of throttle bodies.
    Baby's running MUCH smoother now, especially in the 3-4,000 rpm range!
    2004 R1150R 80th Anniversary Edition, Blue w/Black Running Gear, 178K miles & counting!
    Mansfield,MA
    Nice
    We used to use a similar contraption on the 4 cyl Hondas back in the day.
    Mod Squad
    2009 F800GS 1994 TW200
    Registered User nyfty's Avatar
    Lincoln, Nebraska USA
    Ot
    This is off topic but nice R. I have an 04 just like it. Not many out there with that color combination.
    Jim Nyffeler
    Lincoln NE
    '10 F800GS, '04 R1150R
    BMWMOA 110521, IBA 8936
    Jan 2016
    Central Illinois
    Sync Thing
    Quote Originally Posted by bullfighter View Post
    Be carful if you use mineral oil in that they may think it's a medical device and hit you with the medical device tax!
    Quote Originally Posted by 179212 View Post
    Do you mean mineral oil or castor oil?
    Jan 2016
    Central Illinois
    Oil
    The one that would have helped Elvis
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Very nicely done!
    David Brick
    Santa Cruz CA
    2007 R1200R
    Registered User K7GLE's Avatar
    Apr 2016
    Seattle
    I used one of these for years on my airhead but it way too sensitive/jumpy for the oilhead so had to buy a real one one.
    - Glenn
    2000 R1100RT (current)
    1982 R100RT (traded)
    1970 BSA A65T, 1969 Honda CB350, 1967 Honda CB160 all fondly remembered
    Old and Tired Gillie Dog's Avatar
    Oct 2017
    Southern California
    Okay bullfighter, how about a materials list?
    Cannot make out what the clips holding the tube next to the yard stick are in the picture or what the anti-kink radius piece is at the bottom.
    And what was the liquid? ATF?
    Need to run down to the hardware store now it looks like.
    Many Thanks
    GD
    Nibley, UT USA
    Quote Originally Posted by K7GLE View Post
    I used one for years on my R1100RSL, as a final fine-tune after getting a rough balance with mercury stix. Since you are working one side against the other, all differences are magnified by 2 so yes, it can seem jumpy or sensitive. That can be fixed by adding a small restrictor in each line, like a fitting with a smaller hole.
    Best,
    DG
    DGerber
    1983 R80ST -- 1988 R100GS "Bee"-- 2004 K1200GT w/Hannigan S/C -- 2010 K1300GT
    Jun 2017
    Quote Originally Posted by gilliedog View Post
    Many Thanks
    GD
    I don't recall the diameter of the tubing, but I bought 15 feet of it at the local DIY Center (used to be "Do-It Center"). I looked at a few YouTube videos for inspiration, they said to make sure the length of the tubing is equal on both sides from the radius out.
    The clips are leftover cable clips I had for running cable up a wall.
    For the anti-kink at the bottom, I used a plastic cap from a jar of vitamins (super high-tech, I know!)
    And yes, the liquid is ATF (which is vegetable-based oil, so not subject to medical equipment tax, LOL!)
    And to top it off, I screwed a couple of eyelets into the top of the 2x4 to hold the tubes when not in use.
    Oct 2017
    Southern California
    Perfect. The close up picture was what I needed. Thanks.
    The tubing is all I need to pick up. Have everything else already.
    I will be fashioning one very soon.
    GD
    (New to me) 2010 R1200RT after HD Electra Glides for 35 years
    Jun 2017
    Quote Originally Posted by nyfty View Post
    Thanks! I love this color combo too, it was quite the find
    Jul 2017
    Bunbury WA Australia
    My Version
    I thought I'd post my version of this instrument.
    Can easily checked to see if the gauges 'match' ( accuracy not important if they concur with each other. ), doesn't use any liquid, can be damped easily enough and is robust, although its a bit more work to build.
    Also one has to source econo gauges out of 80's Ford Falcons..... Not too much of an ask in Australia( see them on Ebay a bit ), but maybe harder in other parts.
    I think VB/ VC Commodores use something similar.
    The valves are the 'needle' type so they can be throttled.
    Steve
    Vancouver, B.C. Canada
    Quote Originally Posted by sterob View Post
    Steve
    Are you a plumber by any chance? That's a lot of fittings ya got there!
  1. Can't set throttle body sync
    By franz in forum Hexheads/Camheads
    Last Post: 07-16-2015, 12:44 AM
  2. RT throttle body sync
    By rongrosser in forum Hexheads/Camheads
    Last Post: 06-29-2015, 07:37 PM
  3. Throttle Body sync.
    By samo in forum Oilheads
    Last Post: 12-27-2011, 04:07 PM
  4. Throttle Body Sync
    By ronbo in forum Oilheads
    Last Post: 09-07-2011, 01:09 AM
  5. Throttle Body Sync?
    By JK in forum Hexheads/Camheads
    Last Post: 02-27-2008, 12:09 AM
