Results 1 to 5 of 5
Thread: Long Legs on a 2003 BMW K1200RS
    Hello, I just purchased a 2003 BMW K1200RS and have experience discomfort with my long legs. I am over 6 feet tall and long legs. Will lowering my pegs 1.5 " help significantly. Ain't young either! Trying to decide whether to keep or trade.
    Nibley, UT USA
    Do you have the seat in the upper of the two positions? Pegs in the lower of the two positions? That helps a great deal and should be your first option. Peg lowering kits are available, but my experience is that the RS/GT bikes are already a bit short on cornering clearance and lowered pegs just amplify that issue. Secondly, while it seems counter-intuitive a set of bar risers/setbacks may do more to ease your discomfort than peg lowering, and without stealing cornering clearance.
    I’m 6-2, 34” inseam, and not a small person and managed to find enough comfort for 1k days on my 2004 GT, which came OEM with taller bars than your RS but the same peg setup. IMHO, check all your existing setup and adjustment options before you dive into speedy peg lowering kits.
    Good luck,
    DG
    DGerber
    1983 R80ST -- 1988 R100GS "Bee"-- 2004 K1200GT w/Hannigan S/C -- 2010 K1300GT
    You can ride with your feet on the passenger pegs for long periods. This option gives you four positions.
    Astatula, FL
    If the aforementioned adjustments are not enough, consider a custom seat that allows you to sit a bit further back, and maybe a bit higher.
    Bob Weis
    Bikeless! 2004-bmw-k12rs-hannigan-Sold!
    Quote Originally Posted by 3131bike View Post
    Thanks DG, We are about the same size and I will take your advice and check my present setting. The seat is in the high position. Thanks again, JPV
  1. 2003 K1200RS Questions
    By brianhinton in forum Flying Brick K-bikes
    Last Post: 11-22-2013, 05:50 AM
  2. 2003 K1200RS or K1200GT
    By moralem in forum Flying Brick K-bikes
    Last Post: 06-12-2012, 12:53 PM
