Results 1 to 11 of 11
Thread: Oil Leak
    Dec 2010
    Peoples Republic of Ma.
    Unhappy Oil Leak
    Saturday I removed the cover on my RT and found oil inside. The bike had been parked on it's sidestand for a week without use. Traced it back to the left side cylinder, most likely from the valve cover gasket. WTF? I have 9200 miles on my 2016RT, first the saddlebag problem, then the throttle position sensor and now this. MAX will pick it up for winter storage this month so hopefully they'll replace the gasket.
    Registered User marcopolo's Avatar
    Feb 2005
    Alexandria Virginia/Ottawa, Canada
    When was it last serviced, or more precisely, when was that valve cover last removed? Maybe the gasket is just not seated properly. Happened to me after a service, and simply went back and had it re-seated.
    Mark
    2015 R 1200 GS Adventure
    Apr 2017
    Cooperstown NY
    Check out my " https://forums.bmwmoa.org/showthread...oil-leak!-argh " thread. Same issue with more leakage. Max took care of it...but it looked like they even got into the head gasket for my leak.[I can't tell from paperwork quoted below] nevertheless, they were easy to deal with - but you have to say something- they don't seem proactive to me, but they are responsive.
    Paperwork states: "Installed 11 12 8 542 057 :seal kit, cylinder head ... REPLACED VALVE COVER GASKET [caps on original document]
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by rick601 View Post
    That part number is for the cylinder head cover gaskets (Valve Cover)
    Lee
    2016 R1200RS
    MOA # 30878
    Apr 2017
    Cooperstown NY
    That part number is for the cylinder head gaskets (Valve Cover)
    Thank you sir!
    Dec 2010
    Quote Originally Posted by marcopolo View Post
    6000 mi service but I don't think they removed the valve cover, just changed fluids.
    Dec 2010
    I informed MAX in CT., they will pick the bike up for storage this month so I will be sure to remind them to check it out. I have parked it on the center stand now.
    May 2003
    SW Iowa
    Thank you sir!
    Oops, I meant to type Cylinder Head Cover Gasket.
    Lee
    2016 R1200RS
    MOA # 30878
    Apr 2017
    Cooperstown NY
    Oh yeah? well thanks anyway...and again! BTW- is that actual removal of the head? or are the valves somewhere else? and it isn't called a valve cover gasket?
    May 2003
    SW Iowa
    I consider it a valve cover, but the BMW parts fiche calls it a cylinder head cover.
    Here's what you see when the valve cover is removed.
    Lee
    2016 R1200RS
    MOA # 30878
    May 2003
    SW Iowa
    Slid the door open to the bike parking spot today and saw a small puddle of oil under the left valve cover of my RS.
    It's been 10,000 to 11,000 miles since I checked the valves earlier this year.
    Most winters the temp in the garage only drops below freezing a couple times. This year we have already had a dozen or more days where the garage temp dropped below freezing and had two days it was around 20 F.
    I'm guessing the cold caused the minor leak.
    I'll remove the cover and clean the gasket in the spring.
    Lee
    2016 R1200RS
    MOA # 30878
  1. Gas Leak
    By bobr9 in forum Oilheads
    Last Post: 10-12-2015, 01:00 AM
  2. /5 Oil leak
    By 67986 in forum Airheads
    Last Post: 09-17-2009, 01:42 AM
  3. OIL Leak
    By grumpyone in forum Airheads
    Last Post: 12-08-2008, 05:41 PM
  4. Oil Leak
    By boxerkuh in forum Airheads
    Last Post: 02-11-2007, 01:21 AM
  5. KLT oil leak!
    By Polarbear in forum Flying Brick K-bikes
    Last Post: 05-05-2006, 12:45 AM
